Car CD Changers
Problem for Car CD Changers
Generic problem for all Car CD Changers
2003 Lincoln LS
By bruceh on Oct 18, 2007
I' having issues with my 2003 Lincoln LS 6 CD changer. It abruptly stopped working today. I get a cd error.
I cannot eject the disk, play a disk, or shuffle. I get a "cd error" message.
I am wondering if it is possible to reboot the cd. My experience with software influences me to take such action..
Thoughts?
Comments:
Oct 18, 2007
- just the cd player.
stereo works great.
i'm moved to believe it is with the mechanical changing part of the cd changer. If it is software, I expect to hear some sort of movement noise to output that the cd player is trying to read the disk.
There a technique to unjam or reset the system? I am wondering if I can reset the code of the system and see if the cd player has self check diagnostic capabilities during start up that just might dislodge this pesky behavior.
Replacing is the easy fix, but why can't I make stuff I have now work instead of getting a new one?
Same Problem
May 19, 2009
-   I have the same problem with my 2004 Lincoln Aviator, and the number of discs in my player reads all 6 CDs in the changer. So when I try to press CD AUX button, it kept reading NO CD, and when I press the EJECT button, it kept reading CD ERROR. What's going on?-   Guest
Mar 17, 2009
-   I have the same problem. the cd changer in my 2003 lincoln ls stopped working all of the sudden. However, the radio and the GPS work just fine. I tried also ejecting or changing CDs and it does not let me. Please help!!!!!!-   arianna1224
Feb 08, 2009
-   hey i bought a second hand honda civic. its came with a pre installed blaupunkt washington DJ 70 sound system with 10 cd changer. im having pretty much the same problem, when i try to play any CD, all it says is "CD ERROR". any help? -   aquarian09
Feb 07, 2009
-   hey guys, i have this problem every 9 months or so!, if u disconnect the battery for about 30 mins, usually it makes it work fine again!-   Guest
Jan 12, 2009
-   I'm having the same exact problem down to the T. Any suggestions on how to fix?-   laurentrinet
Best Solution
posted on Oct 18, 2007
Helpful)
zman08
Rank: Guide
Rating: 91%, 12 votes
i think you will most likely have to replace the factory unit. That problem is very common with cd changers. it's a mechanical issue. is it the cd changer on the stereo itself?
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Car CD Changers
Questions and Unsolved Problems for Car CD Changers
Answer
I have a 2003 dodge 1500 with a 6 cd player and it will not switch to the cd mode. It will only go... (More)
Answer
Where can I get a user manual for VDO CD711 car CD/Radio.
Answer
how to hook up with ur radio with fm transmitter u hook up t ur rado antana
Answer
try to find what lead goes in to stereo from the cd changer i have a 52 plate rav4 with atape player... (More)
Answer
i have a mercedes clk 320 with a 6 cd player. the casette will not eject or play
14 Other Users Have The Same Problem - Continued
Comment by JDURHAM, posted on Jan 10, 2009
I have just purchased a USA Spec F100i 6 disc changer. There is a lable on the bottom stating "manual eject" - How do you manually eject the magazine.? Also, does the unit normally have to be connected to remove the magazine? I purchased the unit used and wanted to make sure the magazine was functioning properly before paying someone to install. Thanks, Jeff
Comment by jacain357, posted on Aug 23, 2008
my Cd Changer was working fine until I took one of the battery post off now all I see when I try to play a Cd is 3FFF or CD error but the radio works fine and the GPS.Someone else had the same problem can you help please.2003 Lincoln LS
Comment by annsom7, posted on Aug 22, 2008
I have Jeep 2005 grand cherokee limited and have a 6 mp3 cd nav system also have a dvd player attached to thesystem all factory installed . while driving and listening to my cd it just stopped working and said
" DISC ERROR " it does not recognize any of he 6 cd's and is not recognizing my dvd player also when you go in the mode on the player and choose from Disc / Sat/ Ves --Ves being where the sound from the dvd player comes , it does not even switch to Ves, it goes to Disc and when I press the mode button again it goes to Sat and when I press the third time it should go to Ves but it switches to Disc mode, completely skipping VES mode.
I can take my Cd's out and insert Cd's but my radio plays well. my nav system works fine.
Need help
thanks
Comment by Guest, posted on Jul 19, 2008
202 lincoln ls disc wil not eject
Comment by wlessard, posted on May 27, 2008
I have an 02 Lincoln LS with the Alpine 6 CD changer. Occasionally the CD Error would come up but eventually I could get the CD out. No longer.
I'm trying to figure out how to get into the thing. Does anyone know how?
w.lessard@yahoo.ca
Comment by Guest, posted on May 11, 2008
Same problem. Cds won't eject or play. CD Error.
Comment by Guest, posted on Mar 14, 2008
The same exact thing happened to me with my LS and now I can't get the burned cd's out. They wont eject.
Comment by Guest, posted on Nov 11, 2007
I had the same problem with the Alpine 6 Disc changer a 2002 LS. Dealer said it was caused by using "burned" discs (CDR's as opposed to commercially recorded). I'm skeptical because I've been using CDR's in the unit for six yeasr without a problem. Also, I can't see why the recording format should have any effect on the unit's mechanical ejection system. Since extended warranty applied, I had the unit replaced.
Comment by DaveQ, posted on Nov 07, 2007
DaveQ 2001 Lincoln LS CD Changer Problem
Had a problem with the CD Player just not playing. Purchased a used one on Ebay, and guess what, I have a different problem.Cannot load a CD keep getting Slots Full and CD error Messages.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Car CD Changers:
Top Car CD Changer Experts
Rank: Guru Guru
Solutions: 14904
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car CD Changer Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
