Question about Blackfire 65 Lumen" Clamplight Flashlight
Why is there a flashing green light on my black fire flashlight
It prints ok and with new cartridges. but green start light on and black ink light flashing. why
Hello, your black ink needs to be taken out and cleaned, just dab on a wet paper towel to get the ink running freely and clean the printhead with q tip where the cartridge inserts into, use a flashlight to see, make sure the printer is unplugged from the electric.
Nov 27, 2015 | Canon Pixma MG2520 Inkjet Printer
Screen on Gateway FPD2185 stays black.
The back light is out. Might be the inverter or the tube.
Feb 15, 2014 | Computers & Internet
Flash fires irregularly... good exposures, then suddenly 3 way under exposed/black then a good exposure, the a completely burnt out over-exposed shot! Completely irregular.
If you are referring to the internal flash I would say you are firing the camera faster then the flash can cycle. There is a green lightning bolt that will come on in the viewfinder when the flash has charged. If you fire the first one it may be a charged flash then again you may have popped the flash composed and tripped the shutter before the flash has had a chance to fully charge. You fire again depleting the charge some more and before it has a chance to recover you fire it again so the flash never has a chance to fully charge. You need to wait till the flash ready light come on in the viewfinder.
Dec 18, 2010 | Nikon D70s Digital Camera
Dell 173FP - black screen - green flashing power LED
It can be bad fuse, shorted trnaistors inthe inverter circuits, bad caps, transformer. See the pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Post back what you find so we can guide you further.
Mar 10, 2010 | Computers & Internet
285, red/green lights blink, whines on start up, but won't fire
Hi Dave,
Try shorting out Center Pin to Outside Metal Contact after the light turned green. This must fire the flash.
If not, could be the flashtube /or trigger are defective.
Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Vivitar 285HV Flash
When fitting a Canon 430EX flash to 450D,,light emits but flash doesnt fire, no flash in any mode.
Your camera may have been set to not fire external flash. Go to your menu, 5th tab. Near the bottom, there's an option for Flash Control. Select that. It should now show "Enable" or "Disable". Enable it.
Also "External Flash func. Setting" gives you more options for your 430EX.
Jan 25, 2009 | Canon EOS 450D Digital Camera
Blackfire 65 Lumen" Clamplight Flashlight Logo
55 people viewed this question
Top Blackfire Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Blackfire Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
