The brightness on my tablet has went right down and i cant see nothing at all Excelvan ET703 7'' Android 4.1 Jellybean MID Tablet PC Notebook
SOURCE: android mid tablet passwords help
With any Android 2.1 device you should be able to manage any account passwords through the Settings - Accounts menu (from the main screen, menu button, then go to settings, then to Accounts)
SOURCE: i dropped my android tablet
You can get the part at android Repair and there is a guide that shows you how to put in the part at tablet Repair Guide.
SOURCE: forgot login for Craig 7" Android tablet
how do i do a hard reset on a craig cmp741d 7-in touchscreen 4.0 android tablet
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
