Question about HP Sound Card
No sound is coming from my speakers &headphone
  • Anonymous May 20, 2009
    i went to listen to a video email and no sound came out i had turned the speakers up to high and still nothing.
  • 30 Answers
Do you have already installed your models sound driver. If not, you can download it on google and then type your system model. Or your speaker is not functioning. Or it is not properly connected on you CPU.
Posted on May 19, 2009
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
It turns on,everything works normal and sound even comes out of the headphone jack.but there is no signal coming out of the speaker jacks.no sound or test tone
Hi depending on the design some receivers , when you plug in headphones, speaker sound is disconnected by the headphone socket so it could be faulty, or there may be a separate switch to switch of the speakers, (while using headphones) if so that switch could be suspect. I dont think the amplifier part of the receiver is at fault as you say you can hear sound at the headphones. It is not impossible though that a fuse has blown inside the amp, If you unplug from mains and look inside you may spot a blown fuse , (only replace with one of the same rating).
Hope this helps
pete
Nov 14, 2010 | Teac AG-V8060 Receiver
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
I have a Hohner amp that has sound coming from earphones when I plug them into the headphone jack, but there's no sound coming out of the speaker itself when the earphones are unplugged. How do I fix that?
the headphone socket acts as a switch for main audio and headphone line. either u have a defective socket or the power amp is defective. headphone line is driven by a preamp, which is working - if power amp is defective- headphone works but power amp fails. try changing the headphone socket first.
Apr 25, 2010 | Audio Players & Recorders
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Marshall mg15cd practice amp sound ok through headphones but does not come from main speaker when h/phone lead is removed
Hi davyboy5
Sounds like the speaker has blown or maybe a wire has come off. Sometimes the headphone socket can go faulty also. Do you have nyway of testing the speaker?
regards
robotek
Jun 13, 2008 | Audio Players & Recorders
Using headphones with my yamaha dsp a595a amp
If you turn speakers A and B off together, there should be no sound coming out from your speakers(be sure that you do not have the amp operating in surroundmode.). The headphone cct in this amp is not affected by speaker switching and remains on all the time. v
Dec 11, 2007 | Audio Players & Recorders
Computers & Internet Logo
352 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
