Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Won't stay running
I have this older model and when I start the mower it blows black smoke and soon putts out. If I play around with the handle ( maybe the throttle )I may get it to run but it barely chugs and soon stop altogether. When I lift it backward it sounds as if it is running the right way but I have to hold it up to keep it going. What may be the problem?
    Sniper:
  • 57 Answers
Check the oil level. It may be overfull. If so, a carburetor problem may be allowing fuel to get into the crankcase.
Posted on May 19, 2009
Overfill oil
Did you turn the mower on end or over? If so change the air filter otherwise It sounds like the piston rings are worn out. Rings are cheep but unless its an expensive lawnmower I would just replace it.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The lawn mower won't stay running. It starts up without a problem. I mowed the lawn for about 45 mins and the mower sounded like it was out of gas. It has plenty of gas in it. If I tilt it, by...
Sounds like the automatic choke to me. When it acts up next time, remove the air filter, and observe the butterfly valve on the carb. Hold it open with a screwdriver, and see if it starts and runs. I have found that wireing the thing wide open solved my Toro problems. The mower is still under factory warrenty however, so you can always take it back! Hope this helps my friend!
Sep 09, 2011 | Toro Power Lawn Mower
318 starts but wont stay running blows black smoke out tailpipe. It has new fuel pump, filter,timing chain plugs,wires...
The older chrysler products have a ballast resister on the firewall that is used for dropping the voltage to the ignition coil. During a start procedure, while the key is turned all the way in start position 12 volts bypass the resistor forcing a high output of coil voltage. When you release the key to the run position 12 volts goes ito the resistor & a lower voltage of around 6-7 volts comes out, & goes to the coil.
What happens, is the resistor breaks inside and no voltage is coming out the resistor. Thus only a start condition exist with no run.
Sep 15, 2010 | 1988 Dodge Ramcharger
I have a 13.5 hp briggs and stratton that had got gas in the oil and i changed it. stars good and runs perfect cold. when it worms up the throttle stops working it will only run at high idle with no Chang...
Float isn't working. It is leaking past the needle. Try taking the float out and use a q tip to clean out where the needle valve go's. And inspect the rubber tip carefully. If it has any mis shape or grove. Get a carb kit and rebuild it. That would be the thing to do in the first place. because the gas bypassing the piston and going into the oil will be enough for you to get a new motor too.
Aug 29, 2010 | Yard Machines Garden
My Troy-Bilt mower starts easily but not as powerful, stays on for less than 5 minutes and gradually stops. some black smoke is coming out
If the black smoke comes out of the muffler, you are burning excess fuel and could have an air filter plugged up to restrict air intake and cause the engine to run rich, therefor black smoke.
Apr 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Mower smoking and sputtering.
Sounds like the engine is getting flooded because the carburetor float needle is not seating. Let me know if this helps.donnyb60
Mar 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
479 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
