The reason your "
freezing up in the freezer" is your unit is not automatically defrosting. That part you describe is your defrost control, or at least A defrost control. You said while cleaning the back, safe to assume you meant the outside back of the cabinet? Look for a square plug, either black or white, with the same 3-1plug as the defrost control. But, I doubt that is your current defrost control, maybe the original, but the unit cannot run without the defrost control plugged in. Now, your current defrost control maybe defunct, or your defrost heater element, or bi metal thermostat, the latter two are located in the freezer, one at the top, the other at the bottom of the evaporator coil. Test the continuity through both of these parts, the bi metal t stat at top of evaporator needs to be tested while it is cold. Disconnect one end of the heater element to test its continuity. If both of these test ok, replace your defrost control.
