Question about Arrow Ct50k Professional Cordless Staple Gun Lithium Io
Arrow ct50k staple gun not stapling
Gun not stapling
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
smartr10U
  • 1305 Answers
SOURCE: How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Posted on Jun 08, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
  • 2527 Answers
SOURCE: arrow staple gun will not shoot it seems it is
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Posted on Nov 23, 2010
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
Why doesn't my Arrow fire any staples any more? It's not jammed. The piston doesn't seem to raise high enough to get over the next staple in line. Is it worn out?
Might be could also be that you have the wrong staples in it. Arrow makes about 15 different staple guns. The reason for that is so they can sell you the right for your use staple gun. This also means that certain staples only work for certain guns. Check the model then check arrow web site and find the compatable staples for that gun. Hope this helps
Aug 19, 2014 | Tools & Hardware - Others
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
I have the Arrow CT50 stapler, it won't drive the staple, light works makes a sound like it wants to drive staple but don't. I have adjusted the power to all the way + and the battery shows 4 green lights....
It sounds like the battery is failing low battery voltage equals loss of power. The batteries used in this type of tool are the cheapest ones out there to keep the cost of the tool low, and have a very short lifespan, it is not the number of times used but how old they are that is the main factor
Feb 28, 2011 | Arrow Ct50k Professional Cordless Staple...
How do you load staples
A piece comes out of the rear of the staple channel and the staples go in there.It is spring loaded to push staples to the front of the gun.
Oct 09, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
My arrow staple gun jams every few staples even thought it has a ''jam proof mech''
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Nov 10, 2009 | Arrow T50P ARROW STAPLE GUN
Is the Ace Hardware #22084 Staple Gun the same as Arrow T-50 ?
Found a friend who had an Arrow T-50 stapler and compared staple sizes - not the same.
Feb 17, 2009 | Arrow T50P ARROW STAPLE GUN
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow Ct50k Professional Cordless Staple Gun Lithium Io Logo
53 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
