Question about Husqvarna Garden
Husqvarna chainsaw leaks gas when filling
It doesn't all leak out only when i start filling saw with gas
  • 1 more comment
  • scohen000 Jun 17, 2009
    thnx Jim, got it all taken care of. was leaking from primer hose
  • Jim Parker
    Jim Parker May 11, 2010
    Great!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
  • Jim Parker
    Do you still need help or have you figured out the problem? Where does it leak from?
    Jim
  • 86 Answers
HI. IT SOUNDS LIKE YOU MAY HAVE A PROBLEM WITH THE FUEL LINE, WHEN YOU TURN IT ON ITS SIDE THE FUEL MAY BE LEAKING AROUND THE SEAL ON THE FUEL LINE OR EVEN POPED OUT. ITS HAPPENED TO ME BEFORE. JIMBO
Posted on Sep 14, 2009
  • Mike May 10, 2013
    I pushed and pulled on the fuel line and it re-sealed, the gas was gushing out. I will change the fuel line though, it goes from the carb through a grommet to the tank body to the filter. No grommet in the tank body, just a tight fit !
  • Ken Hollyhurst
    Ken Hollyhurst Dec 19, 2016
    The real thing to check is the fuel tank vent, not the fuel line to carburettor! Mine is a Husqvarna 51. The vent pipe is a rigid plastic tube, look inside the EMPTY tank.Not the flexible fuel line, but the one at the top, throttle end. Now on the outside of the saw, other side from the filler, is a plate held with two screws. Remove. Then you will see the other end of the vent tube deep down a hole, to the throttle side, of where the plate was. IT IS A POUND TO A PINCH THAT YOU HAVE LOST THE VERY,VERY SMALL WHITE POROUS END INSERT. You can carefully press in a new one, without removing the vent pipe.
  • 22 Answers
Sound like you have a tank vent issue. Take it to a dealer to have sorce of leak located.
Posted on Dec 28, 2016
Husqvarna chainsaw oil leaks
I have 4 husky\'s and they leak a little. On the bottom of the saw there is a oil flow adjuster screw turn it down a little also check oil cap gasquet.
Sep 21, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
562xp leaking gas
Where does it leak gas? There is a tank vent that should only flow "in" if this vent is faulty it could leak. If the fuel cap is faulty this could be the leak. Lastly, the fuel lines could be leaking. Clean the saw and see if you can determine the location of the leak.
May 20, 2014 | Husqvarna 562xp Auto Tune 20" Chainsaw
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I filled my 340 husqvarna chainsaw for the first time this year and it leaked gas from someshere opposite the fuel fill tank( maybe near the fuel line). It then quit leaking and just will not start. Maybe...
Opposite the fuel fill is the tank breather, and the return to tank hose if the machine has a primer, the back to tank hose fits on to an orange connection in the tank, it may have slipped off, next to it is the breather the early breather was two white pellets pressed into the tank, these will need to be removed and replaced if this is where the leak is from, the later breather is a white round assembly with a connection on the top, nothing fits to this conection, the breather can be pulled and and replaced if required.
May 01, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My 385xp-husqvarna chainsaw with a 2 foot bar is leaking oil. I cut wood with it last saturday and woke up sunday morning to find a puddle of bar oil under neath of it. This has been a reaccuring event. ...
Husqvarna are reknown for this, remove the pump and pick up pipe with the filter on, slip a rubber o ring the correct size onto the hose, this will space the hose out the distance of the o ring and create a better seal against the oil pump body.
Fill the tank with petrol, this is much thinner than chain oil so you should very quickly see where the leak is.
Dec 04, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
55 leaks gas from cap just installed new one still leaks
most cahin saws have a plastick tank witch splits under presher,, its most likely the tank leaking but it may be a fule line if you lucky
Mar 28, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Bar oil leaks when saw not in use
What you describe is common in many chainsaws. Try loosening then reseating the oil cap before putting her away to relieve any pressure built up in the oil tank. Check all the hose connections.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number of you saw; uncheck "Manuals"; Check “Illustrated parts lists ”; then search.
Serial number breakdown: 06 1500198 (Husqvarna 359)
06 = year produced (prior to 2000 there is no space and only the first digit is used (61500198 could be 86 or 96))
15 = week in 2006 it was produced (March)
00198 = 198th unit produced that week regardless of model or type
Sep 24, 2009 | Husqvarna Chain Saw 20" Bar
350 leaks gas when filling
HI. I JUST TOLD A GUY THAT THAT HAPPENED TO ME AND IT WAS THE FUEL LINE, IT POPED OUT OF PLACE. HOPE IT HELPS. JIMBO
May 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
712 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
