Question about Dell Precision Workstation 670 PC Desktop
Primary fan sounds extremely loud with 2 ea 2.8
Primary fan sounds extremely loud with 2 ea 2.8 gig procs in it. second fan is normal. when a single 3.2 gig proc is installed the primary fan is normal. yes, i have the vrm in when the 2 procs are installed and not when the single is in. dell precision 670 board. this is my home pc.
  • NL71 May 11, 2010
    The configuration you have described will produce noise if you expect adequate cooling for the processors.
    If you require further advice, I suggest that you provide details of the cooling solutions you have installed so far.
  • 105 Answers
In bios setup you can change fan to quiet mode
Posted on May 19, 2009
The fan on my qsc mx1500 poweramp is so loud is that a normal thing?
HI, If there is any lubrication problem or bearing fault the the fan will me noise. Normally the fan will not be very loud. I you have to concentrate hear the sound of fan is it on or not. Here i have added a video which will show you how to lubricate a fan which comes inside electronic equipments. Ajin
Jul 24, 2012 | QSC MX1500A 2-Channel Amplifier
Unable to add more match RAM using secondary slots
You need the motherboard manual to make sure it can take more.
It may only accept 4 gig. For example: 2 x 2 gig strips or 4 x 1 gig strips.Or you may need to use single sided ram boards, chips on only one side. I know some motherboards do.
Feb 07, 2012 | Computers & Internet
I have a 4 gig card in my camera. the camera only records in 2 gig segments. When it switches to the second segment the video goes white and you can't see the video anymore. what could be causing this?
sounds like it is not finished processing the first video. processing power in cameras is usually pretty low, so it is probably just being overwhelmed and needs more time to finish the previous action.
Mar 06, 2011 | Midland Xtc Extreme Action Video Camera...
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
Noisy piece of "Dell" lol
That's a confusing description of the events charles.
Have you identified the cause of the original problem - the dead caps? Is Over Voltage a possibility - have you verified the stability of the PSU?
Apologies if I've misunderstood.
May 19, 2009 | Dell Precision Workstation 670 PC Desktop
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Asus K8N-dl - second processor present but not running...
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
Aug 04, 2007 | ASUS K8N-DL Motherboard
Dell Precision Workstation 670 PC Desktop Logo
676 people viewed this question
Alun Cox
