Question about Tunturi T40 Treadmill
E1 sensor THE E1 SENSOR GOES on when I have walked on the treadmill for just a few minutes
Er1 on power first treadmill will walking
You have to check the speed sensor postion. If there is any problem in the speed sensor then it can lead to the E1 message.
If you wish to get some more details about treadmill error codes and solutions then. Check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | Exercise & Fitness
E1 error after start up.
Does the walking belt move for a brief moment, then immediately stop, followed by the E1 code? Or is there no belt movement at all when start is pressed?
Nov 27, 2013 | Kettler treadmill Pacer
Error E1 on star trak treadmill
please test the speed sensor. see the diagram attached .This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board test the output voltage for input voltage terminal power if there are NOT the board is faulty . The error codes will differ between makes and models but could be e1.
See my personal TIPS for help.
Nov 13, 2013 | Spirit Weslo FREE SPIRIT 815 Treadmill...
When i am running the belt seems to stop for a split second causing me to stumble and then goes normally
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 10, 2010 | Proform Sport 1000 Folding Treadmill...
How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 20, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Tunturi T40 Treadmill Logo
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
