Question about Lexmark X2500 All-In-One Printer
Hi I don t know how to set up my all in one to
Hi I don t know how to set up my all in one to fax from my windows vista laptop I have an x5200 series for lexmark
  • Lexmark Expert
  • 228 Answers
I regret to inform you that the Fax solution software is not developed for Windows Vista operating system. However, you can use any other third party fax software that will work with Windows Vista.
Posted on May 20, 2009
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
My ibm thinkpad is asking me for time code setting and don't know what to do
It sounds to me that your having a problem with setting the time on you ThinkPad. If so Try this:
http://www.howtogeek.com/howto/windows-vista/dealing-with-windows-vista-time-sync-problems/
This will also work in Windows 7 & XP
Good Luck!!
Aug 16, 2012 | IBM ThinkPad i Series 1412i Notebook
When I click the print button, a fax window pops up, and it will only let me fax, and not print
In Windows Xp
Click on start and click on control panel
in control panel look at the top left and switch to classic view(unless your already in it,if ur in it then u'll see a lot of icons and not groups)double click the printers and faxes folder.
now look at the tow icons of your printer and one will say officejet 4300 series and one will say 4300 series fax.
right click the 4300 series and select set as default.
Now click on print if you still get the fax window select your printer icon in the drop down list and then the fax window will not popup.
IN VISTA
Click on the start button and in the start search box type "printers" and press the enter button.
In the printers window single left click the printer icon(4300 series,not 4300 series fax)
Then single right click the 4300 series icon and select set as default.
now close the window and try to print if u still get the fax popup then selet your printer icon in the drop down menu and it will print and not fax
Jun 25, 2009 | HP Officejet 4315 All-in-One Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
HP 2700 serie all-in-one printer
my hp all in one 2700 will not sent a fax my grand son had his hand on my machine it now says that image on fax send report is set to off . how do i set it to on
Jul 10, 2008 | HP Photosmart 2610 All-In-One InkJet...
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark X2500 All-In-One Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
