Zoeller upflush ultima wont flush
Pump is working but not pumping
wbwill
  • 68 Answers
SOURCE: basement up flush tiliet.
Is this a grinder pump with float switch? Or is it built into toilet sump?
First in either case if you can identify the capacitor, get one and replace it, they wear out over time anyway. If that fixes it, you are done the easy way.
Many of these type motors are throw aways, and finding the switch, let alone getting it apart and replacing it is more trouble than buying a new motor if available.
If you are plumbed in, and have no other choice but major construction to replace an up toilet, we can attempt a repair at our shop, if that is against the rules here, sorry, but I know what a complicated and near impossible fix this might be, sometimes the motors are riveted together, so if you need help and want to mail it to me for an estimate, we are happy to take a quick look.
wbwill@sbcglobal.net
Will
Posted on Sep 16, 2008
  • 63 Answers
SOURCE: water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: Zoeller M53, pump keeps pumping half the power
try backflushing with high pressure water(carwash) if that doesnt work you have to remove the bottom plate to expose the impeller and remove debri,gasket will probably have to be replaced(silicone) will do
Posted on Oct 31, 2009
  • 33 Answers
SOURCE: where can i buy a replace float road for a m98-b
zoeller is a pump normally found only at plumbing and heating supply houses. they should carry or can order thge part for you
Posted on Jan 07, 2010
SOURCE: How can I tell if
Depending on the sensitivity of the float switch you may find that the float must be completely upside-down for the pump to turn on. The easiest way to check if the pump works is grab the float by hand and hold it in the inverted position - if your pump kicks in and starts pumping you know the pump itself works and you may want to adjust your float (I use tie-straps around the handle and around the float cord to artificially shorten the float). If your pump does not pump water when the float is inverted try shaking the float to see if the inner switch is stuck. Hope that helps.
Posted on May 03, 2011
Zoeller m267-f pump has power going to the motor but will nut run
Does it have a float switch? Does the motor run when you lift the float switch? If not... then the motor's gone.
Jul 23, 2014 | Zoeller Sump Pump with 25 foot cord 2" 1/2...
Zoeller Pump M57
The only "easy fix" may be a stuck float switch. First make sure the outlet where the pump is plugged in works. Plug something into the outlet such as a work light to confirm the outlet is live. The float switch may be stuck in the OFF position. Giggle the float arm up and down several times to see if the pump comes on.> You can spry wd40 into the switch where the arm enters. If this does not work, the pump probably needs servicing.
Apr 07, 2014 | Zoeller Sump Pump, 3/10 HP - M57
My Zoeller M57 pump has stopped working. It won't even turn on...is there a reset switch or some other easy fix for this?
These Zoeller pumps are very good quality> I suspect that the float switch is not working, which is why the pump is not turning on.You may try giggling the float arm that is attached to the switch. You can also try spraying some WD 40 into the switch where the arm enters. Zoeller does have replacement parts for their pumps. Review their website for your pump parts.
50 Series Zoeller Pump Company
Where can i buy a replace float road for a m98-b zoeller water pump
Jan 04, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Oct 31, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
I HAVE A 8 1/2 DIAMETER SUMP.MY OLD PUMP FAILED. CANNOT FIND A PUMP SMALL ENOUGH TO FIT.HELP!
get a submersible zoeller sump pump the flaot is attached to the pump not a teather and it wilol keep less water in the pit,, this is the best pump on the market
Jun 12, 2009 | Zoeller M211 Automatic Aqua-Mate...
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water backing up into my basement ejector pump during heavy rain
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
