Question about Cycling
Bubble blower on Little Mermaid bike does not blow bubbles
The bubble blower on the Little Mermaid bike comes on, but the bubble blower does not work. You can feel the air coming out the top, and the cup with bubble solution is full; but no bubbles come out.
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Need assembly manual for mongoose
Mongeese manuals here, but not specifc to any models.
http://www.mongoose.com/usa/usaeng/mtn/man_inst
Posted on May 01, 2011
  • 11800 Answers
SOURCE: My bubble blower won't blow
There are hundreds of models, you should have mentioned yours. But, since they all work pretty much the same (the soapy water is sucked out from the tank thru a tube by the lower pressure caused by the passing of the air thru the bubble maker - Venturi effect) , the problem problem appears to be with the tube that connects the bubble maker to the water reservoir: it's either clogged or the hole in the bubble maker tube thru which the water was supposed to exit is too little - you will have to enlarge it a little with a stiff wire or needle.
Posted on May 16, 2011
  • 9 Answers
SOURCE: the belly is full of
Check to make sure the path the bubbles take out is clear of anything in its way. There are also many reviews on this item that say this item does not work the way its suppose to. If you can not get this item working i would suggest taking it back to get a different bubble machine.
Posted on May 30, 2011
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
It worked fine the last time I used it, now it will not make bubbles. What should I do?
Review- Deluxe Bubble Bliss Foot Spa by Hometics ...
? 5:14
https://www.youtube.com/watch?v=LUBHAmA0y3A
Apr 17, 2014 - Uploaded by Calla
I love this bubble spa, its great for anyone who is on their feet all day, Its ... my machine quit working for the bubbles ... My mom bought one yesterday, but it does not bubble. ... make them a little larger so you could submerge your whole foot in ... I'm curious if you've ever used essential oils during your foot ...
The Next Best Thing to a Jacuzzi - Epinions.com
www.epinions.com/.../HoMedics_Bubble_Spa...2/.../130896793220
Jan 29, 2016 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
My suitcase on petz5 wont let me put a bubble blower back its annoying and i want to get rid of it.Please oh please help me!!!!
Okay, get out another bubble blowing box, and then put the first bubble blower in the box with the second one. You can put two in one box and put them away together. Hope this helped!
Sep 28, 2011 | Ubi Soft Catz 5 (Windows) (680901) for PC
The sound lights and bubble part stopped working and we changed batteries. Bike is only three months old.
Let it dry out. Then, try again..or call the company their might be something wrong..a recall or some other type of new part they give for the recall? look on the trike, write all serial numbers/1-800 numbers or email, to contact the company they should help. Good luck!
Jun 05, 2011 | Kiddieland Disney The Little Mermaid Ride...
The belly is full of bubbles and the batteries are in. i can feel it blowing air, but no bubbles come out
May 29, 2011 | Little Tikes Bubble Bellies - Boubly...
I don't have instructions for this as I bought it used. Does the bubble machine need to be filled completely to get bubbles to come out? I was going to try it before Christmas and when I put in a small...
Try filling the resevoir. Another thing that might cause a problem is dried solution in the tube, so running hot water through might dissolve any residue! Hope this helps.
Dec 23, 2010 | Fun Rise Gazillion Bubbles Cinderella...
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 | Home
Fuel lines replacement
The larger of the 2 lines is the pick up/filter line - the smaller is the primer feed line that goes to the pressure bubble...The fittings are different sizes so it should be simple. To test it , with the hose out of the tank..press the primer bubble...it will blow air out of the line...
Apr 11, 2009 | Craftsman 4 Cycle Blower/Vac
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
