Question about Neff 24 in. S5443X2 Built-in Dishwasher
Salt empty warning lihgt not comng on
Salt chamber empty warning light not coming on when empty
Dishwasher salt light wont go out after filling it with salt and everything is coming out white
well,if you fill it with salt and the salt light wont go out,and your dishes came out white,PLEASE STAY AWAY FROM THE DISHWASHER! the salt light is a warning light ,not to fill it but to delime it! wow,
Apr 23, 2015 | Dishwashers
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
The lihgt of my penal don"t come on wend I turn my lihgt
I don't know about that but I really want to know that.
Dec 20, 2012 | AppSmash What I Do
Resetting fuel filter warning light on toyota 2kd
Change the diesel filer element.
Unplug the only connecter on filter housing.
Turn the ignition key to on position.
Go back and plug in the connector after more than five seconds.
The light should go off
Jul 14, 2012 | Cars & Trucks
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Machine does not want to start on any cycle.
Check salt chamber and add salt if empty. Check your inlet water flow.
Apr 14, 2010 | Dishwashers
Hi I have Prius 2001 has warning light on and Engine check lihgt, and Hybrid lihgt on engine runing stop plese advice, Fred Moon E-mail:fredm26@yahoo.com
have the auto parts store hook up their code reader to your vehicle to pinpoint just where the problems are happening. There is normally not a charge to do this. Hope this helps. Leave feedback if it does to help others
Aug 30, 2009 | 2003 Toyota Prius
Neff 24 in. S5443X2 Built-in Dishwasher Logo
16 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
