Question about NetGear WGR614 Wireless Router
Netgear wirelss modem tick not lighting
Green tick is not lighting on netgear wireless modem and as a result will not work, have to use wired onnection. can this be fixed? please help, thanks
  • 1,272 Answers
Please note that the tick light turns on only when the router is doing a self test. If it is on then that means the router is either faulty or doing a self test. If the router is working fine then the tick light should be off.
Posted on Jun 23, 2009
I have a DG834N wirelss router, it has recently kept doping the netwrk connection both wireless and wired, the only way to overcome the problem is to reboot the router, any idea why or solutions?
Sometimes the ISP (Internet Service Provider) might have done something on their network that is causing it.
Try removing the power cord from the modem and the router. Then plug the power cord into the modem only and let it cycle up for about 2 minutes. Then plug the power cord into the router and let it cycle up.
If it still drops, then the router could be going bad.
Jun 07, 2012 | NetGear Computers & Internet
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Our netgear wgr614v7 54 mbps wireless router has gone bad acording to our net work service.They tested there modem,that had astrong signal.now here is whats happnen,there is no signal frm modem to wireless...
This guide gives you the directions for setting up wireless on the Netgear WGR614v7.
Basically enter the routers ip address (192.168.1.1) in your browser. If you router has default configurations, then enter the username as "admin" and the password as "password." Navigate to "wireless settings" and then on that page you configure your network.
Jun 13, 2011 | NetGear WGR614 54 Mbps Wireless Router -...
HAD UNPLUG MY PERSONAL ROUTER TO GO WIRELESS WITH THE CABLE COMPANY , NOW WAS VERY DISSATISFIED WITH THE WIRELESS AND ASKED TO JUST CHANGE TO TURBO AND I WOULD RECONNECT MY NETGEAR WGR614 WIRELESS ROUTER....
Connect Modem to WAN Port on Router
Connect Computer to LAN port
Checked Lights on Router
if the i-Lights amber Powercycle the Whole N/w
then if i-Green check Internet for Wired
then Loginto Router and Do Wirelesss Settings
Scan and Connect to Wireless N/w
Sep 29, 2010 | NetGear WGR614 Wireless Router
How do I resolve my internet port light being amber on my wgr614v7 netgear router
Recommend that you go one step at a time.
1) unplug the wireless router.
2) reset your Cable modem or DSL modem. Wait until the lights show the Wide area network or WAN is working correctly before applying power to the Netgear wireless router.
3) After a minute or so, its signals should change from amber to bright green.
Repeat if necessary. If this doesn't provide the connectivity that you need, a call to your Internet Service provider may be necessary.
Sep 06, 2010 | NetGear WGR614 Wireless Router
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Power light flashing green
the green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
May 15, 2009 | NetGear DG834G Router
Netgear internet light on modem will not turn green
Are any lights showing at all - if this is the case & you have no green lghts at all - then you have a problem with your power source & would suggest that you get a new power cable
Mar 15, 2009 | NetGear WGT624 Wireless Router
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
NetGear WGR614 Wireless Router Logo
1,342 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
