Question about Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum
My craftsman vaccum won't **** very well. The filter is not the problem and the hoses are not clogged. On the motor itself there is very little air being sucked in, however it blows out air quite well. Can this be fixed?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
The mini has a plastic blade, it sounds like it is loose on the shaft. The air you feel coming out is vacuum air and motor cooling air. It will feel like there is a lot of air even if you block the hose, because that's motor cooling air. The plastic blade might need replaced.
Posted on Oct 05, 2014
reddevil6
  • 1673 Answers
SOURCE: Shop Vac not working well
The only thing after the filter and bag is the motor. Do you have suction with the hose removed? If not then the hose is clogged. If you have some, then the motor is the problem.
Posted on Feb 22, 2008
SOURCE: shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Posted on Mar 15, 2009
woobie dog
  • 1273 Answers
SOURCE: every time I turn vac on with hose attached the
Try it with no attachment or nozzle on the end. If it sucks the hose in on itself then, you'll be wanting to check that hose one more time. Pass something with a larger diameter through it. I'd try 3/4" PVC pipe or something like that. Another alternative is to place the hose on the exhaust of the canister and try to blow it out. Yet a third possibility is to reverse the hose on the suction side and **** through the hose backwards.
Best regards, --W/D--
Posted on Aug 08, 2009
pumpkinman
  • 1144 Answers
SOURCE: My shop vac is blowing air out and not sucking.
make sure top is sealed up properly also check to see if hose is not plugged in hose or inside vaccum
Posted on Aug 28, 2009
  • 8404 Answers
SOURCE: Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair: http://www.shopvac.com/support/
Posted on Feb 21, 2010
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Bag was changed, but vaccum cleaner will not reset itself
You could have a clogged hose, afterfilter, or worn/broken control valve assembly.
1. To check the filter, press the tab located at the bottom of the tool holder/air diffuser. See photo below. Lift air diffuser. There may or not be a filter here. If there is, remove it, then check machine operation.
2. Disconnect hose form canister. Turn on machine. Place hand over intake. If the machine turns off during this process, the control valve assembly is broken or worn out. Replacement needs to be done at an authorized Aerus franchise service center.
3. To check the hose, disconnect both ends. Drop a marble or similar size item in one end and allow to roll out the other. If it doesn't, the hose is clogged. This will cause the machine to shut off as well.
Sep 11, 2010 | Electrolux Epic 6500 Vacuum
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
The motor stops while you are using it and the stand by lights up
you are over heating the motor ...that is caused by low airflow ... make sure the bag is not full, hoses not clogged and secondary filters (sometimes on the output side) are not clogged ... make sure there is lots of air going thru the motor .. the motor cant run long without air to cool it ... it has a thermal switch that trips when it gets too hot .. the thermal switch resets itself when the motor has cooled ...
Aug 05, 2009 | Electrolux Vacuums
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Jul 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Bissel upright vaccum model 6594
Did you check the inlet hose down by the brush roll, it may be clogged there. Your system says that that must be a clog. Did you drop something like a big marble down thru the hose and have go all the way thru?
Oct 27, 2007 | Bissell 9200 Upright Vacuum
Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum Logo
163 people viewed this question
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
