Question about LG 23,500 BTU LW2410HR Heat & Cool Window Air Conditioner with Remote
LG lw2413hr that will not heat consistently...sometimes it seems luke warm, others its just cold...why? Please help
System cools fine, but will not heat. I had little heat at first, never got to temp. THen is just went to blowing cold...please help
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
reddyanantha
  • 205 Answers
SOURCE: LG 24000btu not blowing cold air. Fan runs but i
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Posted on Sep 04, 2009
shastalaker7
  • 1515 Answers
SOURCE: have a reverse cycle split system LG aircon
Hi, dealing with these ductless split systems on a daily basis, I can say you have checked some of the things I would have wanted you to check, which is good on you're part.Blowing Room Temp. air in both heating and cooling indicate that the compressor is not running even though the outdoor condenser fan is on.There are several things that could cause this. You have a compressor run capacitor that starts the compressor, but I am thinking on you're unit, it has a dual capacitor that runs the compressor and fan together. Fan is on, so I will rule this out.These units are notorious for leaking freon as the Liquid line and suction lines are not brazed, they are put together with connectors that tend to leak over time. If it is low enough on Refrigerant gas, the compressor will shut off and stay off on low pressure. This unit has a low pressure switch that has normally closed contacts, that opens and stops the compressor from any damage which in turn, you will have no cooling or heating.Do this for me, turn the unit on in cooling, lower T-stat way down so outdoor unit comes on. Go to the out door unit and where the elect. wiring and lines go into unit you will see to copper lines. The largest of the 2 lines is the low or suction line.Wrap you're hand around it and it should be nice and cold. If it is warm, just touch the smaller line, it should be rather warmer, almost hot.If both lines are of normal temp. you are either out of freon or the compressor isn't running.You can remove panel to get to it and put your hand on it to see if it is on. If the lines were of normal temp. and the compressor is not on, more than likely you have lost the charge.Look it over, the wiring to see if you see anything burned or connections burned off and so on. You can check the 3 wires going into the compressor by turning off the power at breaker and removing the cap covering wires just to make sure these wires are intact. sometimes one will get hot from power and burn off. If you see this problem, it would be something you could fix.If all looks good, go back to the copper lines and being this is a Heat-Pump, you should have 3 fittings where we install our gauges to check and fill systems with freon. Look for one that is on the unit itself and remove the plastic cap.Don't be alarmed if you do as nothing will come out.If you look inside the valve, and you see a Schrader core, you can depress it with a nail or something small, just enough to see if it has a lot of pressure in it.If very little or none, the system is out of freon. You will have to call a tech out to find leak and evacuate and re-charge system.I wanted to give you many things to check so you and I would know what the problem is, a process of elimination. If you have a lot of pressure, then more then likely you have a faulty compressor. If you feel that you would rather not check the electrical or depress the Schrader, I fully understand.You can at least check the temp. of the lines and listen to see if the compressor is running, and if it is with warm lines it is still low on freon.Please keep me informed, and again the long explanation was for you to understand more about you're system operation. Sincerely, and best of luck,
Shastalaker7
Posted on Nov 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: it blows cold air for 5 min. and the it blows cool air for 15 min
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
Posted on May 22, 2010
SOURCE: My LG Lan125HV works fine on air conditioning (
I talked to LG customer support (800) 243-0000. The tech told me that this model had a problem with the indoor thermistor. It doesn't fail with an open-circuit condition, so you don't get an error code. The thermister just goes out of range and believes your indoor temp is much hotter than it is. That's why the heating never comes on. I'll bet that, even though it ran in COOLING mode, once your room reached setpoint, it just kept on cooling & cooling ... because the thermistor was still giving a false, high temp reading.
So, I bought a new thermistor, P/N 6323A20042A. My unit worked fine. Until the next week when I turned heating back on and now I have the same problem ... gives cooling but no heat. Something is failing the indoor thermistor OR the distributor sent me an old-style thermistor, I haven't gotten determination on that yet.
Regardless, call LG and see if they can't direct you to a distributor for an indoor sensor. LG's warranty coverage for parts is a royal pain, unless you can show a receipt by a certified installer, you're not going to have much luck getting payment for the part. However, the thermistor is only $10. Just hope you get one that doesn't fail on you!
Posted on Nov 27, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Air conditioning not blowing cold
may have air trapped in it still or thermostat is not working properly..
Jan 26, 2014 | Hummer Cars & Trucks
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
I have no heat coming out in my 2002 ford taurus (3.0l) or maybe a little bit of warm air for 2 minutes if it's plus 5 outside then air turns cool at the windshield and at the feet. This past win
Check your heater hoses..If one is hot and the other is cool or luke warm,,then the heater core is clogged..I know its hard to get to ,,but if its clogged sometimes you can take the hoses off,,and run a garden hose through it and flush it out..
Apr 24, 2012 | 2002 Ford Taurus
I have a 2001 Ford Expedtion and I am having major problems with the heat........I have flushed the system about 5 times and they most recently replaced the heater core. After working good for one month...
You need to have a pressure chek done on the engine cooling system. this will tell you if you have any leaks. some that you can't see. this is the main reason for loosing heat constantly.
Feb 11, 2011 | 2001 Ford Expedition
95 S10 blows cold luke warm air, I've flushed the heater core and seem to have flow, after engine heats up one hose from manifold is warm, the one going to the water pump is cold, when changing the heater...
If one of the hoses to the heater core warm and the other is cold then the heater core is restricted still. Try disconnecting the hoses at the core and flushing to core with a hose go from one side to the other you can likely clear it out and save it. Also check the radiator cap and radiator it sounds like the system is not holding proper pressure. If this is a 4.3 they have a vary large cooling system and the radiators are knowen to have problems not holding pressure they are leaking and you can't even see it. It leaks in a fine mist and is despursed under the vehicle when driveing . For now i think you can save the heater core but it sounds like you are going to have to do a total mantintance on your colling system when the weather allows
Feb 02, 2011 | Chevrolet Blazer Cars & Trucks
Same problem: 2001 Toyota Tundra that won't blow
that is entirely possible yes, could also be a broken cable to change the temp from hot to cold, could be a problem with certain ac components under the dash
Mar 12, 2010 | 2001 Toyota Tundra
The heater in my 2005 Suburban works intermittently. Sometimes it works fine and other times there is absolutely no heat. The fan works but there is just zero heat. There does not seem to be any consistent...
It sounds like you have low coolant in the engine, If your coolant is low you may intermittently have no heat, the rear heater probably gets coolant first, and that is why it seems like it is performing better. With a cold engine add about a pint of coolant above the full line, then warm the vehicle up to regular operating temperature and shut it off. As the engine cools the coolant from the resevoir should be drawn back into the engine. If after the engine cools the coolant level is lower than where you had filled it to, try this again. The reason for bringing the engine to operating temp is that as the coolant ciculates, if their are any air locks in the system they will be circulated out to the resevoir.
Dec 04, 2009 | 2005 Chevrolet Suburban
Engine running to cool
Replace the thermostat. If thermo is stuck open, coolant only heats up when there is no flow over radiator(idle) and then cools down when driving. Also, check coolant level, same response as stuck thermo.
Feb 06, 2009 | 1999 Volvo V70
Very little heat from heater
the selector flap is not moving all the way to cold or hot position. Under the dashboard on the passenger side is a heat/ac box where all the duct work for the vents originates from. inside that box is the radiator for the heater and the cooling coil for the ac. the selector flap between them is stuck or not moving all the way.
Dec 29, 2008 | 1999 Ford Taurus
LG 23,500 BTU LW2410HR Heat & Cool Window Air Conditioner with Remote Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
