Question about Black & Decker BL1900R Blender
BL2020R not starting - Black & Decker BL1900R Blender
Ninja stopped working
Our Ninja 1100 also stopped during blending.
We set it aside and chopped manually.
Next day tried it again - it works.
Reason: motor probably has overheating protection. Must wait until motor cools down enough to re-start. So don't overload or overwork it.
Feb 27, 2014 | NINJA Blenders
Blender will not start
If you have no electrical ability best take it to "the man" Solution is only going to be found by opening it up and testing circuits.
Sep 19, 2013 | KitchenAid Blenders
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Why wont my kitchenaid foodprocessor start?
Take the bowl off, turn it on in the centre at the front where the base of the handle would normally be there is a light coloured button/plastic piece. Push it in with a matchstick. If the motor now starts then you have a problem with the safety switching mechanism in either the bowl or the lid. It is more often the lid. The only solution is to replace the faulty part. Easiest is go to a service agent and buy whichever part solves the problem.
Feb 26, 2013 | KitchenAid Kitchen Aid KFP715OB - Food...
I need a part for my Black & Decker Model BL2020R.
Perhaps you could find Black & Decker parts web-site for your blender model BL2020R. It will show a parts diagram for your machine. Find the part and order it online.
Dec 24, 2012 | Applica Black & Decker Blender With Glass...
Blender 6812 does not start at all
Flip it upside down and take the bottom off and look for a fuse.
Nov 06, 2009 | Oster Blenders
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blender is not starting
Check the thermal fuse located with the field windings .Replace it.
rgds
mloo55
Jun 09, 2007 | Black & Decker BL5900 ProBlend Work Top...
Black & Decker BL1900R Blender Logo
27 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
