Question about Pyle Audio Players & Recorders
Got a Pyle PT798SBA for christmas. What connects to the TV? is there a better manual than just a picture?
Confused by picture in manual. What connects the TV? I have a dvd player and a cable box. Do those go to the Pyle receiver or the TV?
SOURCE: how to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Posted on Jun 28, 2007
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
axebro112
  • 56 Answers
SOURCE: Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Posted on Mar 19, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
WILL IT WORK ON A TV THATS NOT BLUETOOTH CAPABLE
Hi Mike,
The TV requires an audio output jack. Either an Optical, a stereo "RCA phono" type or a stereo 3.5mm "headphone" type jack with the appropriate cable to mate with the speaker's optical or RCA input jacks are needed.
Download the manual from the page linked below under "Manuals and Downloads" and read page 7 where the details of these connection can be seen.
Pyle PSBV600BT Home and Office SoundBars Home Theater Sound and Recording...
Jul 14, 2015 | Pyle PSBV600BT Sound Base Bluetooth...
No picture on my a Pyle PLDN74BTI
bypass parking brake w/no switch codes
Oct 06, 2012 | Pyle PLDN74BTI Car Video Player
PYLE 1600 AMP Hookup Diagram
Hello
Get into this link. You can download the manual for your Pyle amp. You can see all the details about its connections there.
www.pyleaudio.com/manuals/PT24-28.pdf
www.pyleaudio.com/manuals/PZR600.pdf
Dec 18, 2011 | Pyle Car Audio & Video
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
Where do I set switch for pyle pvc2 volume control
I had the same issue and recieved info from PYLE. See attached picture for switch settings and terminal screw identification. Kp
Jul 01, 2010 | Pyle Slide Volume Control
I get inconsistent results in using the auto channel search such that I can't synch the TV to the Comcast cable box. Any thoughts? This is a new Pyle 15 in. LCD TV TV/DVD.
use any other connections to your tv, not the one thru rf input.
i.e: audio/video, component,hdmi, etc.looks like there is a tuner issue, plus you'll get a better picture quality by using other options. if that' hd set, you will take advantage of this feature, if not, just improved picture and no hassle to screw in that "comcast's" thick RF cable in.
Good luck,
Alex's TV.
Feb 22, 2010 | Pyle 15 in. LCD TV/DVD Combo
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Can't get anything to show on TV screen..No menu or anything..
I'm still confused. Walmart has this with pictures. This DVD player has regular RF Coaxial TV output and input. But, the best way to connect it would be Video Out and Audio Out for the connection from the DVD Player to the TV. I guess it has a tuner in it? or else why would it have a TV input on a DVD player?
Specifically the Pr, Pb, and Y connectors and the Red and White - Left and Right Audio Out connectors.
That would give you the best audio and video to most modern TV for last couple of years. (I don't see HDMI but that would be even better if it had that.)
So does your TV not have Component Video (Pr Pb Y) inputs? And Audio Left/Right inputs?
If not then you are connecting Coaxial Cable RF input to your tv? The TV would have to be in TV mode in this case and on the correct channel ... I would imagin Channel 3 or 4 of the old NTSC style TV channels. Most TV's still do those - even with the new Digital TV channels being active.
Nov 22, 2009 | iLO DVDR05 DVD Recorder
TH37PX70BA - Plasma TV. TV has been fine since we got it just after christmas but suddenly the picture has gone yellow, literally it was fine one second then yellow the next, any advice? Is this a known...
It was nothing to do with the TV it was the way the scarts from the Sky box and DVD player went in, swapped them round and all is fine...in fact the picture seems better!
May 18, 2008 | Panasonic Televison & Video
Sharp LC 32ST1E
It sure does sound confused.
Try a factory/default reset on the tuner, then unplug the TV from the power, leaving it for about 10 mins, plug it back in, then re-scan the channels.
Jan 18, 2008 | Televison & Video
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
