Question about Whirlpool 21.6 cu. ft. Top Freezer Refrigerator ET22RKXG
I have a whirlpool refg that will not auto defrost.
The freezer stays frosted on the back wall,the refrig is below and dose not cool.
  • Whirlpool Master
  • 4,654 Answers
Inside your fresh food compartment is a defrost timer hidden behind the tep. control panel. Most panes have a hole or plug you may need to remove to turn the timer. I need you to turn it clockwise slowly until compressor stops running. Wait about 30 min. to see if the refrigerator comes back on. If not we need to replace the defrost timer part # 482493
That is providing the model number above your post is correct.
Model Whirlpool ET22RKXG?
Let me know, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 18, 2009
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Keeps getting error code dh and the fridge isn't staying cold now
Your refrigerator is telling you that it is not sensing a current flow through the defrost heater circuit within a certain number of hours. Could be a bad defrost heater, or a thermostat / fuse package located in the upper right hand corner of the freezer, behind the back wall of the freezer compartment. The reason the refrig is getting warm is that the cooling coils (behind that back wall of the freezer) are blocked up with frost, preventing air flow across them and on up into the refrigerator compartment. It is a bit of a pain to get the back wall out inside the freezer, but it will have to be done. Melting the frost off the coils with a hair blower will temporarily solve your cooling problem, allowing a week or so to get the part(s) you need.
Feb 07, 2011 | LG LFX25960ST Stainless Steel French Door...
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
Mar 29, 2009 | Whirlpool Refrigerators
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrig ok, freezer is warm
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Whirlpool Refrigerators
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
