Question about Canon XL1S Mini DV Digital Camcorder
Tape ejection cartridge that holds tape is not opening all the way. I had to remove the two small white clips in order to remove my tape, which had been "eaten' apparently during rewind in VCR mode
  • 515 Answers
The cassette tray motor might is more than likely damaged, and will need to be replaced. Before you go this route, make sure there is no debris inside the unit, causing it not to eject all the way. Unfortunately, this is not a cheap fix. The XL1S parts are not cheap, and they are labor intensive. So be prepared to shop around to get the best price.
Hope this helps some.
TWEAK A/V LAB
Posted on Nov 09, 2007
SOURCE:
Eject lto5
in the manual should be something like this:
Manually Removing a Tape Cartridge
If problem-determination procedures identify the tape drive as the source of the problem and you are unable to eject the tape cartridge using the eject button, reset the drive to recover the cartridge:
Press and hold the eject button for 10 seconds, then release.
The status light turns amber and the drive starts through its hardware test process.
When the hardware test completes, the status light turns green.
If a cartridge is in the drive the status light flashes green until the cartridge is rewound.
The status light turns solid green when the rewind is complete and the tape drive is ready.
Although it is from an older LTO version, it must work on the newer versions too.
I also did remove tapes, if nothing worked, but it is to much to tell and show here.
NOTE: Allow at least 10 minutes for the rewind process to complete.
Jun 09, 2014 | Computers & Internet
My philips dvdr3510v player is not opening tray its saying blocked how do i solve the problem
This seems to be a manufacturing problem. When the disk is loaded it is centered on a spindle and to make sure that centering succeeds a magnet mounted to a small white rotating plastic piece on the top of the DVD drive. The magnet seems to bee too strong on my machine so the spindle isn't able to disengage when trying to open the tray. The result is blocking. It is of course possible that the electric motor moving the tray and the spindle movement is too weak. Anyhow this is how I solved the problem on my Philips Video/DVS DVDR3510V:
1) Disconnect the device from mains power.
2) Unscrew the eight screws holding the top in place.
3) Unscew four black screws keeping the DVD unit fixed to the main body.
4) Carefully drag the DVD slightly back which allows you to rotate it to point sideways (this allows simpler testing of the mechanical working).
5) Unscew the two blank screws keeping the front half of the top of the DVD unit in place.
6) Using a small screw driver carefully bend the clips to allow the top plate to be removed.
7) Connect the mains power and don't ouch anything inside.
8) After startup try Eject/Load several times to ensure that the DVD unit is mechanically working OK. If the Eject/Load doesnt work with the top off there is no use going further.
9) Disconnect mains power.
10) Use a small felt tipped pen to mark the face of the small metallic (magnet) part in the center of the white movable component fixed to the top.
11) Using a small flat screw driver carefully open the clips holding the two halves of the white component together. Careful! The clips may break easily.
12) Cut small pieces of tape (or use thick drawing paper). The idea is to lift the magnet slightly upwards. We thus use tape or paper as shims. Notice that a hole is needed in the center.
13) When the shims are in place put the magnet back oriented correctly (if you didn't mark it test it against the spindle rotating the disk. The correct orientation is where the magnetic force is strong.
14) Mount the halves back into the hole in the top component and align the clips. Then press the halves together until the clips connect.
15) Put the top component back and clip it into place. No need to screw in the screws yet.
16) Connect mains power, don't touch anything inside.
17) Check that the tray now opens both with a disk and when empty. Check that a DVD is recognized correctly (too little pressure leads to disk loading failure).
18) If the DVD unit now works assemble it and you are done.
The first picture shows the white round plastic part that is modified on the left hand side of picture.
The second picture shows an additional support I glued to the top with super glue because the top is fairly flexible. Initially I thought this was the reason why the spindle got stuck. I think the extra support is unnecessary but i didn't bother with removing it.
Dec 29, 2010 | Cameras
I wasn't able to pull all of the white tape surrounding the staples out when I loaded the staples. Now, the copier is saying that we need to load staples. How can I open the holder to remove the tape?
You have to be careful. Remove the bottom of the cartridge by releasing the four clips that hold it on. Make sure you put the little lever looking part in correctly when you reassemble. This is how the finisher determines the out of staples indication. Remove the staples and put them back in with the arrow aligning with the clear arrow on the cartridge.
Oct 29, 2010 | Canon imageRUNNER 5570 Copier
How do you remove printer heads on cx3200
The two clips that swing down and hold the ink cartridges can be easily removed without breaking anything or removing screws. Look at the hinge points and use a screwdriver to gently pry one hinge of each clip out and the clips will simply lift out. But after that there are 2 small screws that hold the print heads in that ink cartridge carriage. Remove them and keep track of them. The white clip positioned in the color ink cartridge bay helps to hold the ribbon cable in place, but once you see what will move in regard to the print head, you can loosen the white clip and the print head should lift up. In this way, conceivably, the CX3200 print head should detach from the ribbon cables (there are 2) and a new one goes in its place. I'm dealing with a friend's CX3200 that the black is not printing and I'm cleaning it out and finding a lot of dried sticky ink. Probably used until dry or refilled the cartridge with the wrong type of black ink.
Apr 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
Sony PC-105 - camera won't charge, hence tape will not eject. Is
I just had the same issue except I left my camera out in the rain. My camera is a DCRF-HC32 Sony Handicam. There is a reset button on the side of the camera where the eject door is. Take a paper clip and hold the reset button in for 5-10 secs. The camera will beep, power on, open the door and it ejected.
Jan 21, 2010 | Sony Handycam DCR-PC105 Mini DV Digital...
Toner light
I taped a very small white piece of paper over the sensor eyes on either side of the cavity where the cartridge fit. I read that coloring in the actual "windows" that are on either side of cartridge also may help so I did that too.
So open the front, remove cartridge, look on the cartridge for a small circle and color them with black marker (or use electrical tape), look where they would have aligned inside the cavity, tape a small piece of white paper over those sensor eyes.
I just did this and it stopped the blinking. Don't know how long but based on my reading, one of these was the trick.
Jun 17, 2009 | Brother HL 5140 Laser Printer
Tape comes out of cassette when ejected.
Your VCR is "eating" tapes, this is a common problem. First, wind the tape up by sticking a penny or other rounded object into the white "gears" on the back of the tape (with the tape hatch open by holding down the small button on the left side of the tape) and turn either clockwise or counterclockwise. Then check inside the VCR for moisture and remove any and all moisture with a clean rag. Moisture can cause the tape to stick to the VCR's internal components.
Best of luck to you.
May 30, 2009 | GPX TVR950 VCR
Tape will not eject servo reaches halfway but sticks XL1s
Try this...
Hit the eject button. As soon as it makes it half way, take the battery out.
Leave the white cover open, put the battery back in.
This should take the tape cartridge up all the way and eject the tape.
I had the same problem and it ejected the defective tape
Kawal
Jun 23, 2008 | Canon XL1S Mini DV Digital Camcorder
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
156 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
