Question about Salter Health & Beauty
Kgs or lbs
How do I change the display to Stones and ponds? Salter 9073 WH3R
SOURCE: stuck in kgs, cant remember how to change to
1 kilogram = 0.157473044 stones
or go here . . .
http://www.convertunits.com/from/kg/to/stones
Posted on Jun 10, 2009
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Posted on Jul 28, 2010
  • 12 Answers
SOURCE: Taylor 5568 scale will not display lbs - just kgs
Don't know if this will help, but here is the manual.....see my photobucket link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Posted on Jan 29, 2011
ankitchandel
  • 141 Answers
SOURCE: how do you change from
press mode then check it ...................
Posted on Mar 19, 2011
SOURCE: i have a health o meter scale that shows kgs not lbs how can i fix that?
There must be a button where this can be changed in the same way as when changing from 24 hour clock to a pm/am clock.
You can also use arithmetic.
1pound is 0.453 kgs.
The thumb rule is two pounds to a kilo plus a bit, or 0.906 kgs
Good luck
kolbrun
Posted on May 30, 2012
How do I change kgs to read Stones and pounds?
Let's first convert kg to pounds, and then convert the pounds to stones and pounds.
Start with 75 kgs. To convert to pounds, we multiply by 2.2, or double the amount and add 10% to it. I get 165 pounds.
The next step is to convert the 165 pounds to stones and pounds.
There are 14 pounds in a stone, so we divide the pounds by 14. In this case we get 11 stone with a remainder of 11 pounds.
I hadn't heard this term until I visited the British Isles and one of my co-workers was told he was 3 stone overweight. His nickname became "3 stone."
Good luck,
Paul
Nov 17, 2015 | Office Equipment & Supplies
Does anyone know how many average size bluestones one coould put into the aluminum tray of a 1992 Rodeo. Or what the caring weight of this tray might be.
weigh a sample of your average bluestones and divide that into 1000kgs (1ton) and by spreading the stones all over the tray that will be the total number that you can carry. So if you average weight is 10 lbs (5 kgs) then you could fit 200 stones on the tray. If you cannot weigh the stones because of size then load the tray until the distance between the axle bump stop and axle has decreased by half . This will be within the load limit . Any more and you can be considered overloaded.
Apr 25, 2014 | 1992 Isuzu Rodeo
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
Mar 23, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Convert 20 kgs to stones
About 3.15 stones (3 stones 2 pounds).
Mar 06, 2014 | Office Equipment & Supplies
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Taylor 5568 scale will not display lbs - just kgs when I tap and step on it. It's the Biggest Loser body comp model. It was working fine,displaying lbs, then one morning it ws just kgs and I can't get it...
Amy
Jan 10, 2011 | Taylor 55684102 BODY FAT BODY WATER...
Change lbs to kgs
to convert lbs to kgs, just divide lbs by 2.2
Dec 30, 2010 | Health & Beauty
Health & Beauty Logo
44 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
