Question about Phase Linear UMP8015 CD Player/Receiver With Detachable Face
My phase linear uv8 will not take the cd(dvd). How can i get it to work? It had been working fine and then it started telling me there was a disc in it, but there was not, and it says bad disc.
SOURCE: Not Reading CD"s!
try changing the red and black wires around at the back of the stereo
Posted on Jan 07, 2008
SOURCE: My Phase Linear UV8 and my Ipod
Ok the thing is, the unit is installed already. I need to know how to access the back of the unit to hook up the ipod. As far as how to take it out (of I guess it's called a "harness") hook up the cord and put it back in.
Posted on Nov 25, 2008
SOURCE: Unlock region code on my Phase Linear UV8
I had the same problem and I was able to fix it myself. call me and I can help you over the phone 951-334-2297 ask for George.
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
Posted on Jun 08, 2009
  • 69 Answers
SOURCE: I need the code to disable to parking break to
you will need the remote control to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Posted on Aug 17, 2009
Testimonial: "worked like a charm. thanks much for the help!"
Linear phase uv8 and letting my kid watch movies while i drive
You can let your kidwatch DVD but not while your driving unless the screen is out of the view of the driver
Feb 17, 2010 | Phase Linear UDV9010 Car DVD Player
I have the uv8 phase linear and burnt cds wont play only store b
I had the same problem - its because when you burn the disc, you don't use up all the recording time; and the read light on the player is so sensative that if there is any unused time, it will not accept the disc. So, make sure your recording time exceeds the disc space, and make sure the last song you burn is not your favorite because it will cut off midway through the song.
Jul 02, 2009 | Phase Linear UDV9010 Car DVD Player
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Feb 14, 2009 | Audiovox UV8020
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
PHASE LINEAR UV8
that model has a adaptor that comes with and you plug that j-link to it i have one.
Jan 20, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UMP8015 CD Player/Receiver With Detachable Face Logo
306 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
