Question about Vizio E550VA 55 in. LCD TV
Vizio e550va digital audio out not working
Stopped producing audio from this output
3 Suggested Answers
  • 362 Answers
SOURCE: where is the audio output on my vizio e421va
simply doesnt have an output at all some do some dont yours does not route the audio signals to an A\V receiver instead
Posted on Dec 20, 2010
Slinteriors
  • 8617 Answers
SOURCE: need new lcd for vizio e550va
Its quite possible but you would have to compare the tag numbers on the screen you have compared to the replacement screen. They must match perfectly because the Tcon boards are matched to the specific LCD panel.
Posted on Jun 25, 2012
NO VOLUME WITH A VIZI TV 55INCH E550VA PICTURE IS FINE
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 13, 2016 | Vizi E550VA 54.6" LCD HDTV
No sound from TV or sound board?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 18, 2015 | Vizio E550VA 54.6 LCD HDTV - 1080p,...
55" vizio model E55OVA shuts down and says no imput, then comes back on in 15 to 30 sec.
Bad cables or jacks . Do a wiggle test on them and that will tell which one
Mar 02, 2015 | Vizio E550VA 55 in. LCD TV
Vizio e550va as no sound
Please search your model number here. http://store.vizio.com/support/
Jul 04, 2014 | Vizio E550va Pc Board
I need a replacement stand VIZIO E550VA
I suppose you already tried writing to co. on it's website? They should offer replacement parts. Or E-Bay?
Dec 14, 2013 | Vizio E550VA 55 in. LCD TV
Need new lcd for vizio e550va
Jun 23, 2012 | Vizio E550VA 55 in. LCD TV
How to connect a vizio lcd hdtv to my 1976 kenwood KVA 503. My Vizio has no speaker outputs except a digital optical audio. I had it hooked up before and then moved and now I can't get it back...
Obviously the digital optical connector was never connected to the vintage Kenwood.
It sounds like your Vizio is NOT the actual root SOURCE of the TV audio but it's coming from a Cable Box which DOES have various audio outputs. Connect it as you would any other analog audio source (except don't use the PHONO input).
Jun 30, 2011 | Audio Players & Recorders
How to connect my Vizio vsb200 to my sharp lc-42sb45ut?
This television does not have audio outputs so you wouldn't be able to connect these two devices--well the one digital audio output this television has is not compatible with any of the inputs on this Vizio. Double check please by looking for a hole/input on the Vizio that will match up with that on the Sharp television. If I am wrong and there is one then you would need the digital audio cable. I believe this television takes a coaxial digital audio cable, and the hole that would correspond to this cable on electronic devices is normally black in color.
If I am correct and there is no way to connect these two devices directly then you would connect your devices to the Sharp television for video only and connect their audio cables to the Vizio's inputs.
Mar 08, 2011 | Sharp Televison & Video
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
I need a digital audio cable to connect to my surround sound amplifier from vizio HDTV (digital audio output connection)
yes and no. most set top boxes have a optical output that can go to the vizio, but you can also connect a regular right and left audio cable too. Now from your set top box or cable box or sat box you can go to receiver in digital cable. that is the better way to go.
Apr 01, 2008 | Audio Players & Recorders
Vizio E550VA 55 in. LCD TV Logo
15 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
