Washing Machines Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Burnt Rubber smell and spin cycle didn't work
A couple of weeks ago, we experienced the burnt rubber smell and the washer would not spin. My husband replaced the belts and the washer was working again. Yesterday, I loaded a small load and the same thing happened, burnt rubber smell, so we turned it to the spin cycle and nothing happen. Any ideas on how to fix or what happened.
  • schmidty965 May 18, 2009
    What would the cost of replacing the couplings CDN $ be
ALBERT GARCIA
Level 3:
  • Master 975 Answers
  • Posted on May 18, 2009
ALBERT GARCIA
Master
Level 3:
Answers
975
Questions
5
Helped
358421
Points
2970
The main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
It has gotten very loud and makes banging noise in spin cycle, now I have found hard plastic strips after wash and smells like burnt rubber.
Hello. Most likely the transmission has gone bad resulting in dislodging of the tub causing the plastic and the burnt rubber. This is probably not worth repairing unless it is under warranty and less than 3 years old. This is the perfect time to get an energy star washer which has a government rebate of 75 dollars. Joe
2answers
Washing Machine has burnt rubber smell
your problem is probably the coupling that ataches the motor to the transmission , take the skirt of the washer off , take the motor off and you going to see the rubber coupling if is bad just change it , cheap part
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
