Question about Yard Machines Garden
Starts ok wont pick up speed
Stihl strimmer fs 280k starts but wont run very well or wont pick up speed when you pull throtle lever
  • 22 Answers
Check to see if the throttle cable is hooked up to the carb. look at the back of the motor and watch as you pull the the throttle to see if the cable is hooked up. if the cable looks to be working correctly then pull the spark plug up and heat it up with a blow torch and put it back in. if the motor runs good then you need a new spark plug. if those two things do not work then you need to replace the carb diapram and gaskets.
hatter1
Posted on May 19, 2009
Diagram for servicing FS 552 stihl strimmer will not fire up
For a service manual, contact Stihl directly.
May 04, 2017 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Starts ok and runs ok after I have pushed in the choke but cuts out as soon as I touch the throttle. Can you help?
sounds like the ethanol gas messed up your carburetor. Gotta hate this gov't mandate to use this hazardous fuel. 10% ethanol =10% gas mileage reduction.
Stihl wont warranty any of their products that use ethanol gas. They want you to buy this very expensive 'REAL GAS' about $7 a quart
May 07, 2015 | Stihl FS 85 Weed Eater
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Thanks;
George
Oct 08, 2013 | Garden
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
What is the petrol/oil mixture ratio for a STIHL FS 36 R Grass Strimmer?
Hi, 50 to 1 with stihl oil or 25 to 1 with any other brand 2 cycle oil. Hope this helps, regards Phil.
May 30, 2011 | Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Jun 02, 2009 | Garden
Garden Logo
304 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
