Question about Noritz Water Heaters
Heavy vibration - Noritz Water Heaters
    Problem Solver:
  • 7 Answers
Mine was due to an incorrect gas manifold pressure setting. Call Nortitz technical support and they will walk you through setting it correctly. You will need a manometer but a cheap one will cost less than $100 and is cheaper than a service call.
Posted on Apr 22, 2014
Inducer motor noise
Replace the motor.
Jun 29, 2017 | Water Heaters
Inducer motor noise
Never trust anything that comes to you new because usually they are made in china and are not consistent, but next time make sure clean air is being supplied if impeller gets dirt build it becomes imbalanced and will draw high amps and create that vibration noise. Also vibration noise can be caused by improper combustion set up.
May 15, 2017 | Water Heaters
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Bosch AquaStar 2400ES-LP Problem with Vibration while running recently. I seem to also be having a problem with lower water pressure in my Neighborhood - could these be related and causing boiling inside?...
Vibrations were caused by the worn water pump bearings. They could be reduced by reducing the speed of the pump. Vibrations in the water system that is connected to your neighbor may be caused by a change in pressure in the system, if the water pipes are not isolated, and they touch the wall at some oscillation frequency.
Oct 16, 2017 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
I am occassionally getting a moaning vibration, seems to be in the gas line. 1" supply to the house 3/4" branch for the waterheater which is the first appliance. hard piped all the way, is it possible...
Maybe, but if it works OK and you only need to eliminate the vibration then it's going to be one of two things. The pipes themselves might be vibrating, or you may be getting a regulator and gas vibration (like a flute or a horn). As a simple test, try putting a locking pliers or a heavy c-clamp on the pipe, maybe in a couple of places. If this eliminates the problem, then it's the pipe vibrating and you only need to clamp some weight in place as a permanent solution, but don't make a direct metal connection unless you're certain the metals are the same. If that doesn't eliminate the problem then its the horn problem and you could make a geometry change (changing the length of the pipe - adding a couple of bends with additional fittings) good luck
Oct 15, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
When hot water is turned on the pipes make this vibrating sound.
A rumbling more than a vibration? If one in the same, the heating elements may have calcium build up which causes perculation like the perculator coffee pot which causes the heater to vibrate or rumble. If the elements can be removed they can be cleaned by soaking in lime away or a descaling solution. All said and done it will work like new.
May 03, 2009 | Water Heaters
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
135 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
