Question about Car Audio & Video
2001 Mazda Millenia Door Panel Removal
I'm trying to remove the passenger door panel of a 2001 Mazda Millenia to diagnose speaker problems. Does anyone have instructions.
I have removed the obvious screws on the bottom of the panel and inside the storage compartment. The upper half of the panel will not budge. There is no obvious way to remove the window control or door lock control panels.
Thanks in advance for your assistance.
NR
    Novelist:
  • 149 Answers
Should be some screws in the door handle/armrest and you can use a screwdriver around the edges to pop the rivets they are just plastic and can be replaced for a few dollars if you mess a few up-or they do sell a door panel puller tool also-the whole panel should come off as one piece handle buttons and all and will be limited in the distance you can move it due to wiring bundles connected to door locks power mirrors and stuff-hope that helps
Posted on May 20, 2009
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
Door handles wont open doors
Fixed 1997 Ford Explorer Door wont open - YouTube
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
98 Ford Explorer Door Won't Open Part 1 - YouTube
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
98 Ford Explorer Door Problems- how to open without panel ...
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
Rear doors can't open from inside - Ford Explorer and R
Jan 05, 2016 | 2001 Ford Explorer
2004 honda accord ex how to remove pasenger side front speaker
You must remove the door panel (apply gentle pressure around several points between panel and door, end removal of at least one screw in the inside door handle). Once the interior panel is removed, there are several screws holding the speaker in place. Remove these screws and the speaker (once disconnected from the wiring) will come out.
Jan 15, 2014 | Vehicle Parts & Accessories
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
My passengers door doesn't unlock, so annoying! I don't know what to do, it won't unlock manually (by unlocking all doors) or with a key.
The locking mechanism has come undone from the lock or is jammed. You will have to remove the door panel and figure out if it broke or just came loose.
The mechanism looks something like this except it will have a vacuum actuator. I will past the door panel removal instructions below. Let me know if I can be of any further help.64a6bcb.gif
door panel removal:
  1. Remove the window regulator handle.
  2. Remove the arm rest.
  3. Remove the door lock knob.
  4. Remove the inner door handle cover.
  5. Using a flat screwdriver, gently separate the door trim panel clips from the door.
  6. Lift the panel to remove it and disconnect the speaker or mirror wires as required.
  7. Installation is the reverse of removal. Make sure the sheet of plastic behind the panel is properly sealed against the metal to keep drafts out of the interior.
Sep 26, 2010 | 1997 Volkswagen Golf
I have a Mazda MPV 2001 van that two of the automatic windows have stopped working. Is this something that I can fix myself?
On my MPV the problem was actually the Switch not the motor. Check the switches. You can access them by just pulling the door panel off. If you need some instructions for door panel removal let us know.
Hope this helps...
Oct 16, 2009 | 2001 Mazda MPV
How do i remove the inside door panel of a 1996 b2300 mazda? I am trying to replace the speaker.
Ask local parts store to recommend door panel removal tools. Inexpensive. Custom made for many different application and type of cars.
Jul 07, 2009 | Mazda B2300 Cars & Trucks
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
Driver side door mechanism
Can you open the door with the inside handle? If you can, the problem is probably a broken plastic fitting inside between the outside handle and the door latch. There are door panel removal tools available at your local parts store that look like short handled wide bladed pry bars. You could get by with a good stiff putty knife if needed. Take off the arm rest, window crank, and speaker grill if you have aftermarket speakers. Slide the door panel removal tool under the edge of the door panel and CAREFULLY pop the clips loose from the door frame. You could always leave the window open and do the "Dukes of Hazard" thing, but then you would have to change the paint scheme.
Apr 15, 2009 | 2000 Suzuki Esteem
Door panel removal
The book says 1. remove panel pull strap 2. remove door handle bezel 3. on 1995-2001 models,remove power accesory panel and trim panel upper extension. 4. remove armrest screws and pad. 5. remove window handle,I guess if not power windows.
KD makes a tool to go in between door panel and door to pop the door clips loose. KD 3705
You will also have to have a window crank tool if it is manual window. KD431
Hope that will help.
Mar 23, 2009 | 2001 Chevrolet Silverado 1500
Car Audio & Video Logo
676 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
