Question about Taylor 3519 Compact Digital Thermometer
Display reading LL.l - Taylor 3519 Compact Digital Thermometer
2002 jeep Cherokee display says done
After read OBD codes in odometer, and... if no codes are present, then DONE appear on display (from http://www.wjjeeps.com/faultcodes.htm ).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 17, 2012 | 2002 Jeep Grand Cherokee
What causes the temp reading of LL.L?
The SkyScan temperatures only register a certain range, typically -4F to 158F. If it is below this range, it will read LL.L and above it will read HH.H. However, I have been having trouble with mine reading the correct temp, so I often get very whacky numbers, and LL.L is becoming more frequent. Hope that helps!
Dec 30, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
e. Press Hand Wash.
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Display on outside of phone is turned upside down and none of the keys work when pressed.
This is the typical problem faced by slide and flip models. There ll be a strip connecting display and motherboard of your phone. That would have damaged. If you give it to service station they ll tel it is display problem and ll change the whole display. You tel them to change the strip alone so that you can save some money. There is no problem with your display. Hope this helps!! Rate if you feel it is useful !!
Aug 18, 2009 | LG CE110 Cellular Phone
Display reads F22, dryer shuts off after 1 minute
To enter the diagnostic mode, choose any selector button other than Pause/Cancel and do this little keyboard dance:
Press and hold for three seconds,
release for three seconds;
press and hold for three seconds,
press and hold for three seconds.
You’ll know you’ve entered diagnostic mode because all the indicators on the console will light up for five seconds and you’ll see the code “88” in the Estimated Time Remaining display.
the F22 Code you are getting is the exhaust block or overheat!!! DO NOT USE YOUR DRYER UNTIL YOU CLEAN THE EXHAUST OUT! this is a MAJOR fire hazard
it may also be as simple as a lose wire or something like a bad sensor but chances are that your dryer is doing what its supposed to so that you dont have a fire :)
~lee
admin @ WhyPayForHelp.org
Apr 29, 2008 | Dryers
Cd reading problem
I solved it by putting the player to my reseller on my warranty. I bought it in december. It´s as simple as that for the moment. I´ll tell you if it comes out something interesting.
Thanks Anyway.
Feb 18, 2008 | Cambridge Audio 840CB
Taylor 3519 Compact Digital Thermometer Logo
95 people viewed this question
Top Taylor Home Experts
Donni Steen
Tom Chichester
Are you a Taylor Home Expert? Answer questions, earn points and help others
