Question about Dell Inspiron 1100 Notebook
Won't follow through on start-up process
My Dell Inspiron 1100 notebook won't start up. When I push the power button, I can hear it "chirp" as it spins the disc drive, but that's it--nothing comes up on the screen. I've tried re-starting several times, tried turning up the display brightness, tried getting into the BIOS. Help!
  • Dell Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 18, 2009
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
I just got this Dell Inspiron 1100 laptop used from Ebay that arrived on Thur Aug 15th. I installed my DDR memory and my 250gb ide hard drive. The laptop fired right up. And I installed XP Pro. ...
XP Pro! Now there*s your problem Mythbusters would say. Hence its going to become obsolete of security service after 4/2014, its not that MS is going to make it easy to install "new bastardo ones" into the system...
Aug 17, 2013 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My dell laptop inspiron 1100 won't start up. When I turn it on it go's to a screen that says it's now installed firmly in to the port bay and I can't get past that screen. I've tr
Turn off the computer. Hold the Fn key and power key to boot the computer in diagnostic mode. Follow the onscreen instructions to see if you have any hardware issues. This sounds like bad sectors on the OS boot partition.
Jun 28, 2017 | Dell Inspiron 1100 Notebook
Dell mini inspiron mini won't shut down
Force off by pressing the power button for 10 seconds or more. Boot into safe mode, type msconfig in the run line, disable everything that starts. Restart normally, re-enable each program untill you find the one giving trouble.
Aug 30, 2011 | Dell Inspiron Mini 10 Notebook
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
Inspiron 1100 wont boot up,screen stays black,i can hear the fan running,sounds like hd is starting
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 20, 2010 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 screenn is white. Can hear
Chek for loose connections of your screen. Nothing with the equipment, its with the monitor's internal wiring.
Aug 10, 2009 | Dell Inspiron 1100 Notebook
Wont start up after ram upgrade
Try reseating the memory and if that doesn’t work, install the 512’s one at a time to see if one might be defective. If the laptop still won’t turn on, reinstall original memory and see if laptop powers on.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Notebook Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
