Question about Kenmore Washing Machines
Need help taking off control panel on Series 600 Kenmore washer
Model #11027642600
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 600
These washers are not designed to have the back panel removed. They are designed to have the entire cabinet come off in one piece. Its a failrly simple procedure. Just follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console
does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp the case under the front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
NOTE: o reinstall the back panel correctly you will need to pop the case loose from the frame and reinstall. That's why I included all these steps.
Read through everything thoroughly. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Posted on Oct 28, 2009
  • 1937 Answers
SOURCE: Kenmore Washer 80 Series is leaking. Water and
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110-25864400
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on Jan 17, 2010
  • 254 Answers
SOURCE: Kenmore washer model 110.24872300, need to romove control panel
if u got rooom just tip the unit back and get acesss underneath it will be a lil bit tighter space to work but will save you the time and hassle of removin the concole......... u will need a part # 285753A- whirlpool motor couplling.... most those consoles remove though by screws on backside corners or front corners, remove those tilit concole back remove brass brackets, wiring lid switch, pull cabinet off hope this helps
Posted on Feb 03, 2010
mreid542
  • 166 Answers
SOURCE: Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Posted on Jun 16, 2010
Kenmore washer 600 series model 11027642600
Could be bad hose, valve or seal in the washer (this was listed under dryers). Requires taking the washer out of service and looking for source of the leaks. Hose, valve or connectors is more likely than a seal if water is gushing.
Jan 11, 2014 | Washing Machines
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
How do I remove the control panel on Kenmore washer 110.27642600
Hello, welcome to FixYa.
I understand you have a Kenmore washer model #11027642600 you'd like to access the control panel, correct ? The info you'll find below is for changing the lid switch, but it will also guide you in how to open the control panel...hopefully it helps.
http://www.youtube.com/user/RepairClinic#p/search/0/MFsvLiuTniU
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...skip to 0:52 of the video for your model)
If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video.
Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore water level switch broke off. i have an 600 series washer. can this be fixed on my own? the washer still functions fine but it is stuck on small load. how to fix it?
yes it is easy to repair there are two screws on the rear corners of the control panel if you remove those the control flips up and you can change the switch. you can order it from sears parts online with your model number
Jun 06, 2011 | Washing Machines
I have a Kenmore 600 Series washer - model # 110.28622700 I need a repair manual for it. It will not do anything in any cycle
You need the model number which will be inside the lid opening it will say mod or model and begin with 110 then go to www.whirlpool.com and type your model number into the top right corner where it says search and you will be able to pull up the manual in pdf format hope this helps. Sounds like a bad timer possibly.
Jan 07, 2011 | Kenmore 24032\24036 Top Load Washer
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
