Question about Krups XP2010 Espresso Machine & Coffee Maker
Does not brew - Krups XP2010 Espresso Machine & Coffee Maker
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
Jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Mar 28, 2010 | Solis Master 5000 Espresso Machine
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Gaggia Synchrony Brew Unit Block
You have got the gears out of alignment. You don't really want to take out brew group unless at end of cycle. You can fool machine to get brew group back in.
Here is how :
BREW GROUP REMOVAL AND DRIVE GEARS ADJUSTMENT
FOR AUTOMATIC MACHINES
If you ever find yourself in need of removing a Brew Group that has jammed. This will assist you in doing so correctly.
To fix this problem follow these simple steps:
You will need a #1 Philips screwdriver
1.) First, open the door on the machine and remove the drip tray and dredge drawer
2.) Locate the nickel size hole in the brew group. It will have an "N" next to it. At the 9 o'clock position, you will see another hole about 1/3 of the size of the first. Directly behind this hole, or about an inch up depending on the position the machine was stopped in you will see a single philips head screw. You may have to look around the side of the brew group to locate the screw as it is not always visible from the smaller hole. Remove this screw; it holds a small coupling water inlet (it is similar looking to a tobacco pipe) to the brew group.
3.) Remove the brew group by pressing/pushing (depending on your machine) on the part that says “Press" or "Push”. Pull firmly and straight out. Be cautious to not break the brew unit. Also be aware of the door of your machine as it can break as well.
4.) With the brew group out, remove the small coupling water inlet (tobacco pipe) that is probably still stuck to your machine and reinstall it in the brew group as it was before. Make sure the screw is installed snugly but not too tight.
5.) Turn the brew group around so you are facing the back. Now imagine what a check mark looks like, the top we will call position A (longer part of the checkmark) and where the checkmark ends (the smaller portion) is point B. You will notice what looks like a large checkmark where the coupling water inlet is located. The water coupling can slide up and down in this checkmark opening. The water coupling should be in the B position.
REINSTALLING THE BREW GROUP
To do this, the gears will have to be reset to the start position. In order to do so, you will have to bypass the three micro-switches (Brew Group, Dump Box and the Door switch).
Bypassing the micro switches:
1.) Looking at the back-side of the brew group, not the side that says "Push" or "Press," you will notice something fin-like or nose shaped. This piece fits into a keyhole or coin slot looking slot in the machine and that is where the brew unit micro-switch is located. Take something like an index card, envelope, or folded up piece of paper, and insert it into that keyhole so that it will trick the machine into thinking that the brew unit is installed. Start the piece of paper at the top of the slot and slide it to the bottom of the slot. The paper should be thick enough so you can let go and it will remain in place. Leave this object in there until the following steps are complete.
2.) WITHOUT putting the brew group back into the machine, reinstall the drip-tray and dredge drawer and close the door.
3.) After doing so you can then turn the machine ON. At this time the gears will begin moving until they return to the correct start position. At this point remove the object from the keyhole position and you can now reinstall the brew group. If the brew group does not go back in correctly, try a few more times. The machine will return to its home position. Note: The two large spokes of The brew drive shaft should in the Up position
At times, the gears in the brew drive assembly will not complete the cycle to the proper
start position for different reasons. Some of the reasons are:
• Brew group jammed or blocked
• Either one of the micro switches in the brew drive have gone bad.
• Brew drive motor Failure.
• Broken teeth on either of the brew drive gears.
• Dirty brew group, covered by coffee grinds.
• Brew group or gears not lubricated.
• Connections to the board from brew drive assy., or motor have gone bad.
A jammed or blocked brew group happens when the brew group starts the cycle but doesn’t finish it.
Dec 21, 2008 | Gaggia Super Automatic Espresso Machine...
Krups XP2010 Espresso Machine & Coffee Maker Logo
26 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
