Question about Canon Legria FS306 PAL Flash Memory Camcorder
How to initialize sd card - Canon Legria FS306 PAL Flash Memory Camcorder
Check memory card - initialize - complete initialization -process terminated with error! Can You help me?
Just delete files off the sd card and you are good to go! Just solved this problem myself!
Oct 12, 2012 | Canon Legria HF200 Flash Media Camcorder
My sd card wont read. it says that its not initialized. i flipped the thing in the sd card but nothing changed. how do i get my card to work. it worked fine until i put the sd card in the printer over...
Had you ever initialized (formatted) the card, especially when you first got it? If not, an unformatted card will work fine initially, but almost always corrupts with time after many pictures are added. To prevent this issue permanently, you should always format a new card. But note formatting will erase the card! If you haven't saved your pictures yet, and you're having trouble locating them on the card with your computer, see this article. After you've recovered and saved your photos, format the card IN THE CAMERA using the camera format feature (look for it in its menus). This will rejuvenate the card, and prevent this from happening again.
Jan 09, 2011 | Cameras
Locked sd card in camera praktica dcz6.8.
If you eject the SD card, On the side of the SD card there should be a switch you can move up and down, move the switch to opposite of what it was initially.
Feb 09, 2010 | Cameras
My Kodak (SD Card 512MB) Memory Card Says Not Initialized ?
Pls. format the card.
Check if CD card lever is down/up
Test w. a different SD.
If your SD card is faulty there is a warranty on it.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jul 20, 2009 | Kodak Cameras
Memory card sd
Appreciate the direct "Ask Me".
It would seem that you would have to do it all over again, that is download the pictures again to the SD memory card. But before doing this, you would need to format the SD card using the digicam rather than the PC.
In some cases, it maybe that the picture files (downloaded from the computer) does not match the image property requirements of the digicam so that even if the image files are stored in the SD memory card, the camera is unable to list/view them
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | Konica Minolta DiMAGE G500 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon Legria FS306 PAL Flash Memory Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
