Question about Dishwashers
Dishwasher model number W10438345 will not start when I push the start button
I HAVE A DISHER WASHER I have a maytag dish wsher model number W10438345 that will not start. The cancel cycle button works and will run the canel cycle but when you push the cycle start button nothing happens
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
futureloginn
  • 734 Answers
SOURCE: Dishwasher won't start
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Dec 02, 2008
buddymcl777
  • 67 Answers
SOURCE: Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
Posted on May 19, 2009
thunderalley
  • 432 Answers
SOURCE: Whirlpool - only Heavy wash cycle works
bad timer
Posted on Sep 13, 2009
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
Mar 01, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
My disher washer is making a high pitched sound when I turn it on.
is this a new unit or old one? the high pitched sound is the pump some models make this sound every time they start up. it will make the sound when you start it up but then goes away. try this before you start it run the hot water in the sink let it get hot turn off the faucet then turn on the dishwasher.
Feb 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our Maytag MDB8600AWS uses a lot of energy. I use the disher 1 to 2 times a week. My last electric bill was $200.00 more and the usage was the dishwasher. We installed the disher in late Dec 2010. We...
Are you using a high clean setting? We had one that had "pot scrubber" as a setting and it used a lot of electricity.Look to see if there is a low power setting using less heat. In general they do use a lot of energy.
Feb 03, 2018 | Maytag 24 in. MDB8600AWS Jetclean II...
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher will not fill with water
make sure you have the door lock on,also make sure there was not a knock ring on the disher washer side,did you remove the disher hose and check to see if hose is clear and disher hole is clear?let me know-mike
Jun 15, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Dishwashers Logo
193 people viewed this question
Top Dishwashers Experts
