Question about Gaggia Titanium Espresso Machine
Water wont stop coming out of steam valve when making coffee on the titaninum gaggia
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
SOURCE: PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Posted on Aug 07, 2008
EsWorld
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
EsWorld
  • 1618 Answers
SOURCE: hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Posted on Aug 28, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Cubika: no pressure, no coffee comes
The machine needs to be descaled.
Posted on May 04, 2010
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
When I turn on the steam valve , nor water nor vapor comes out , coffee dispenses well
Probably a faulty "Steam Valve Cam" (plastic) which are prone to failure and then do not allow the steam/hot water needle valve to open.
Jun 03, 2010 | Gaggia Titanium Espresso Machine
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Where to fix my Gaggia
If you are unfamiliar with semi-automatic machines you might have neglected to prime the machine: open steam valve with a small container at the nozel, press coffee delivrery button and wait til water runs into the container,the close steam valve and water should come through shower head. This is very basic. If no solution then the head group might be jammed with old coffee grinds. See coffeegeeks forum on subject.
Dec 30, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
18 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
