Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Need to replace the starter cord for Tecumseh Lev 90-120
2 Suggested Answers
2strokeguy
  • 183 Answers
SOURCE: Need to replace starter cord on Tecumseh LV195EA
This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
4. Remove what is left of the old rope.
5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
9.Reinstall everything in reverse order.
Posted on Nov 02, 2010
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
How do I take the pull cord wheel and spring off my Tecumseh Vantage 35 to replace it
There are little metal tabs that hold the wheel in place, bend these out then the whole assembly will come out. When replacing use the other tabs and wind the spring in, line up the cord hole then insert the cord, tie knot then release.
May 02, 2013 | Tecumseh Garden
Hi, I have a Tecumseh HMSK 80-110 snowblower with electric start. Everything was running fine until the last attempt to start it. I pushed the start button and it appeard to be dead. No clicks or...
either the electrical start switch on the unit or the starter motor is bad,you can test the start switch with an ohmmeter,make sure the cord from the wall to the plug in on the units good too
Mar 22, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
How do I replace the starter cord handle on my Tecumseh engine model HMSK90 (snowthrower). The product category selection SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
REMOVE THE STARTER..........REWIND THE SPRING/PULLEY BY HAND AND USE A NAIL OR SOMTHING TO KEEP IT FROM UNWINDING.......NEXT INSTALL THE NEW ROPE WHALA JUST LIKE NEW! HOPE THIS HELP
Nov 19, 2009 | Mtd Garden
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Toro GT 5 6.5 hp Tecumseh model #Lev 120 and it just quit. Checked everything. Good fire,turns over good but have a kickback while it's cranking. Everything else is working. Is there a wire...
Sounds like the blade hit something solid when it was running & then it had problems soon thereafter. It may have sheared the flywheel key & is not firing at about 7 degrees before (TDC) top dead center. Pull out the plug & put your thumb tightly over the spark plug hole to feel for compression as you slowly rotate the blade or pull on the starter cord. About 7 degrees before TDC is when you should get a spark. Maybe you can download a repair manual for it or have a friendly repair shop tell you when it is supposed to fire the plug.You may have to pull off the shroud over the pull cord/flywheel to see where the magnets are at TDC. I had this happen to my Lawn Boy after my grand son used the mower. A $3.00 new key solved the problem BUT it was a pain to take the top covers off. apart
May 09, 2009 | Garden
My Tecumseh Snow King 8HP snowblower won't start. I need to know how to start it with an electrical cord.
In order to start it with an electric cord you must have a feature called an electric starter. If you dont have the electric starter on your machine now, one can be added at a dealership
Jan 13, 2009 | Vacuums
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
18 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
