Question about Dishwashers
Why would my older KitchenAid dishwasher (part#9743822) control board not work after working on the bottom rubber ring
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
  • 534 Answers
SOURCE: kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Posted on Feb 17, 2010
goldenglove1
  • 144 Answers
SOURCE: I have a KitchenAid Whisper Quiet Dishwasher. Has
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Posted on Aug 07, 2010
  • 3 Answers
SOURCE: Kitchenaid dishwasher KUDS01....
the pump is stuck. remove motor.insert plastic pen into bottom of motor.remove impeller by turning counter clockwise.file bottom of impeller stem.put enough washers on the keeper clip to prevent the impeller and the pump housing from binding.reassemble and there you have it!!!!
Posted on Sep 21, 2010
Won't start, green flashing light next to start button. Tightened door screws last week. How do I fix this
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
Oct 19, 2015 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid D/W will not start, lights not all working, getting power. What's my problem?
Sylvia.....is the clean light flashing or any other for that matter? Either way it sounds like the control board is locked up. There are many posts on here about how to reset it. Try the following: With the door open:
Push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry (all the lights should light up) then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. This will unlock the control board and you should be able to restart the dishwasher. There are many issues with this Kitchenaid including the door popping open during cycle issue. I have dealt with all of them over the past 8 years of ownership. Finally replaced it with a used Miele and sold the KA on craigslist with full disclosure of all the issues and it's history. I even threw in the rubber door stopper that we resorted to using to keep the door closed. Let us know if the above procedure works for you. Good Luck.
Nov 30, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
How to reset control board on kitchenaid dishwasher
Check to see if there is a manual behind the bottom panel. It should tell you what that error code is. It may be the heater is not working or some other issue. You will have to repair the problem before this will stop.
Oct 02, 2014 | KitchenAid Dishwashers
Kitchenaid kudd03stss dishwasher locked indicator remains on, nothing else works
Hi
First try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Oct 03, 2011 | KitchenAid KUDD03STSS Stainless Steel 23...
I have a KitchenAid Whisper Quiet Dishwasher. Has been working fine. Circuit breaker seem to be working but control board is now not lighting up and buttons do not respond. Seems like no power to...
Aug 07, 2010 | KitchenAid Dishwashers
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
Kitchenaid dishwasher, control panel is not
Sep 01, 2009 | KitchenAid Dishwashers
Dishwasher stopped working during rinsing cycle.
1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
Good luck
Vlad
First Choice Appliance
Jan 05, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
May 23, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
