F & P Smartdrive 9 Excellence 6.5 model;GW608K
Replace main seal
  • 1294 Answers
SOURCE: Fisher and Paykel - SmartFisher and Paykel - SmartDrive (9) Excellence 7.5 - Pump Blockage
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
  • 109 Answers
SOURCE: F & P Smartdrive Excellence works fine until
Hi Kiri,
F&P mahcines are a little hard to drain as the drain hose comes out of the rear of the cabinet half way up.
You may have to use a small container and manually bucket it out.
The drain pump is more than likely blocked (seen this a lot on the F&P) and is accessable from the front panel or underneath the machine.
Repost if you need anymoe help!
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
SOURCE: fisher & paykel excellence 7.5 smart
www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/426991_aw_uc.pdf
Posted on Sep 14, 2010
  • 72 Answers
SOURCE: how to unblock fisher and paykel excellence
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Posted on Sep 25, 2010
We have a Fisher and Paykel Excellence 7.5 SmartDrive 9. I think we lost wedding ring through it. Do these machines have a coin catcher in them somewhere?
have a look under the machine where the tub hose goes to the pump
the catcher is in that hose
the tub hose will go in the top and the pump hose in the side so that any items drop to the bottom and are not put through the pump impeller
Mar 16, 2017 | Fisher and Paykel Washing Machines
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel smartdrive excellence 7.5
The pump has a thermal cut out fitted,
Pump must have over heated and cut power to machine.
Replace the pump to fix this problem.
Feb 04, 2012 | Fisher Washing Machines
How to unblock fisher and paykel excellence smartdrive washing machine
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Jan 07, 2010 | Fisher Paykel Eco IWL16
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
