Question about Pride Health & Beauty
Chirping sound in motor, brake assy HOT, lugs unlock pause relock will improve power loss cel-leb X
  • chuck sage
    chuck sage Dec 29, 2013
    full charge performs good 15 min then feel drag and speed drop sometimes unlock brake wait few min lock and will improve for a few min then repeats problem the brake assy way too hot to touch
  • Pride Master
  • 1,263 Answers
Hi, now there it could be one of two faults, the brake magnetic core is not releasing the brake , other-words it's dragging or the voltage from the controller is not high enough or not enough current , a controller fault...check the wiring going from the controller to the brake... now a simple test would be to remove the brake but still have it connected via the two wires and tape on to the motor now you must be careful here because the scooter will roll if near a incline etc...so you been warned !!!! ... does the scooter run okay now ?
I do repair brakes..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Dec 30, 2013
My car chirps while increasing speed and when I brake my vehicle.
It is possible that the broken tab is your problem because the tabs keep the hardware from moving, especially when you apply the brakes. To determine if this is the case, remove the tire,brake caliper, brake pads, and hardware. Put one of the lug nuts(or two if needed) back on to hold the rotor in place. Spin the rotor by hand and listen for that chirping sound. If you don't hear it, the hardware is the problem. If you can still hear it, check that metal plate that protects the back side of the rotor to make sure its not bent and rubbing against rotor. Also check that nothing is rubbing on the trans-axle(if its front-wheel drive). If all is well in these two places, the only thing left that spins in that area is the wheel bearing. They usually make more of a grinding or roaring sound but sounds can be tricky.. I am a mechanic for a car rental company and often have to diagnose problems by the sound they make. I hope this info is helpful.
Jan 17, 2016 | 2003 Buick LeSabre
I have a Monarch Vogue and Monarch Sprint mobility scooters. After 20 minutes of use the motors on both scooters are getting very hot and then stop.
hi Phillip , sadly that does not sound good,
One common known cause of this fault is the brake starting to release , other-words stressing the motor .. remove the brake however keep it connected and see whether this improves thing however be careful, the scooter will move if on a slope ..
1. are the brushes the right size ? and do the brushes move feely within the motor brush holder ?
2. Is the Armature clean ?, the gaps ...
3. Has the motor been removed and refitted if so has it been coupled to the gearbox correctly ?
4. The windings of the motor can be breaking down however this would not cause the brush area to become hot unless it causing too much current to draw...
Regards
Rob
Aug 16, 2015 | Health & Beauty
When I hit the brakes the motor stumbles
It sounds like it might be a ruptured diaphragm inside the power brake booster assy. It's the large round dome that sits directly back of the brake master cylinder and uses engine vacuum to assist with braking. Try this: with the engine running listen carefully under the dash in the area where the brake pedal in located as you press on the brake. If the diaphragm is ruptured you should detect an increased hissing sound as the engine stumbles. That would be the sound of a vacuum leak. If so you'll have to replace the booster assy. Hope this helps! Dan
Mar 25, 2015 | Cars & Trucks
WHEN I DRIVE MY KIA SPORTAGE IT MAKES A RUBING SOUND LIKE REAR BRAKE ?
Are you sure it's the brakes? If brakes are rubbing they'll get hot and the wheel lug bolts will too.
Put on old clothes, drive the car down the freeway on a Saturday or Sunday morning, when there's no traffic, being careful to not touch the brake pedal (except as needed). When you've heard the rubbing noise for fifteen minutes or so, pull way over somewhere safe & park. Turn the engine off & apply the parking brake. Go to each wheel and touch the lug nuts and/or the brake drums or discs the wheels are attached to. If a brake's dragging the disc or drum will be scalding hot. If the brakes are not hot, the rubbing sound isn't brakes.
Nov 25, 2014 | 2007 Kia Sportage 4x4 V6
Normal performance 10 min of use then drags like brake on loses speedbrake assy gets hot unlock freewheel and pause relock will help run better for awhile
Hi, now there it could be one of two faults, the brake magnetic core is not releasing the brake after a period of time, it's breaking down , other-words it's dragging or the voltage from the controller is not high enough or not enough current , a controller fault...check the wiring going from the controller to the brake... now a simple test would be to remove the brake but still have it connected via the two wires and tape on to the motor now you must be careful here because the scooter will roll if near a incline etc...so you been warned !!!! ... does the scooter run okay now ?
Regards
Rob
Dec 29, 2013 | Pride New Mobility Celebrity 3 wheel...
Loss of electrical power in cabin
I would suspect the ignition starter switch.
Aug 24, 2017 | 2007 GMC Sierra 1500
How do u diganose engine codes on a 1985 dodge 600 se 2.2
If you have an obd reader, there is a wire under the hood on the passenger side where obd connector can be plugged
Aug 26, 2010 | 1985 Dodge 600
Every time i unlock my hyundai coupe it relocks its self its a 2004 v6 model
the accent does not have a v6 eng. but if it is an accent, with power locks, sounds like a bad power door lock actuator.
Oct 18, 2009 | Hyundai Motor 2004 Accent
Set the combination lock on the driver door of 1999 Ford Explorer
check your car manuel and it should tell you to solve both
Jun 09, 2009 | 1999 Ford Explorer
Replacment of wheel lug bolts on rear wheels
The bolts can be replaced 1 of 2 ways w/o pulling axle. Need to take rotor off and either press bolts out with an arbor press or can be tapped out with a copper or brass hammer. Once out, the new ones can be pressed in by putting about 4 or 5 washers on and then tightening the lug nut down until the lug is pulled snug into the roter. Once snug, the roter can then be reinstalled on the wheel and brake assy put back. Caution!! Brake assy needs to be supported up out of the way with wire or coat hanger while removing rotor. Undo force of weight on brake pad assy can damage hose or unit itself.
Jim Pochurek
Aug 07, 2008 | 1999 Dodge Durango
Health & Beauty Logo
47 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
