Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 after upgrading drivers, it keeps on saying cant unlock maps. How do I fix\ unlock maps if iI havent loaded any new maps
  • 385 Answers
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
Posted on May 19, 2009
How do i upgrade my garmin nuvi 200 gps? (never been upgraded
Download and install the Garmin commuicator plugin to your computer
http://www8.garmin.com/products/communicator/
This will allow the nuvi to transfer data back and forth to Garmin's server.
Connect your nuvi to your computer and run the Garmin WebUpdater to update the software on the nuvi.
Download and Install WebUpdater.
To update the mapping, you will need to purchase a map update subscription.
https://my.garmin.com/maps/chooseDeviceType.htm?
Once the subscription is activated and registered to the nuvi, follow the download instructions to download the map. This will usually take from 3 to 4 hours or more depending on your internet download speed.
The nuvi 200 is a discontinued model and you may want to consider upgrading to a new GPS as a new nuvi with lifetime mapping can be purchased for about $150.00.
http://www.gpscity.com/garmin-nuvi-1390-lmt.html
For further assistance you may want to contact Garmin support.
http://www.garmin.com/us/support/contact
Aug 14, 2011 | Garmin nuvi 200W GPS Receiver
I have a 200 nuvi gps, it always takes me the long way to my destinaotion, how do I update it?
If you are willing to spend $89.00 you can purchase a lifetime maps update/upgrade through the Garmin website. All you have to do is log into their website - www.garmin.com - connect your Garmin to your computer with the USB cable and purchase the upgrade. You might want to consider purchasing a new Garmin that comes with lifetime maps as your 200 is an older unit and its life may be short. A new unit, like a 1300LM, runs $139.99 at Best B**, as of 01/30/11, will come with a new fresh battery and the newest maps pre-loaded and it will allow you to update those maps FREE for the life of the unit. These ideas might help you wayward travels. GOOD LUCK
Jan 17, 2011 | Garmin nuvi 200W GPS Receiver
My garmin keeps saying loading maps every time i try 2 use it and not working
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Dec 03, 2009 | Garmin nuvi 200W GPS Receiver
When garmin 200 is turned on it says it is loading maps and after you hit the agree button it says"no detailed maps found that support routing. the nuvi cannont be used without them".
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
___________________
Sep 05, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuvi® 200 Car GPS Receiver
Unable to unlock maps for garmin nuvi 200 I am having trouble getting new stuff on my Garmin Nuvi 200. I registered it thinking it would let me download mapsource and it didnt. So then I got a pirated...
Here's a thought: instead of trying to install pirated maps which don't/won't work on your unit, how about actually buying the maps which are guaranteed to work. You will get a free copy of Mapsource on the disk with the maps of Europe.
Feb 01, 2009 | Garmin nuvi 200W GPS Receiver
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Oct 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
825 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
