Question about Acer (KV.16X04.007) DVD Drive
How do i open the cd/dvd drive on a asus sonic master
3 Suggested Answers
  • 106 Answers
SOURCE: Downloading music tracks to a blank CD using Sony Sonic Stage software
go into the settings for sonicstage and select your dvd drive. that should be it. but you may have to do other things(i have a sony player too, but i have found sonicstage to be a waste of space and time. it is rather a pain. try looking through the manual and seeing if you have any options for the location of the cs drive. if not, then get a usb cd burner and connect it to the laptop. that should work properly.
Posted on Sep 06, 2008
emissionwiz
  • 79847 Answers
SOURCE: How do I open the cd/dvd drive on an asus desktop
there is a small hole in the front of the drive, use a straightened paper clip and insert that in the hole in the drive face, push, the drive will pop open
Posted on Jun 24, 2010
I have a asus sonic masters laptop and it wont go past the logo screen what can i do
Does it have a DVD drive?
If it does, then you need to get the Windows OS software handy.
At startup, press F8 or F2 or F10 (depends on your PC) but you are attempting to enter BIOS setup
Select boot order and then select the disc drive as 1st option; save and exit.
Next, pop the DVD drive open and insert the OS software disc inside and close.
Power your PC on and wait for it to detect the OS software.
Windows installation will start.
Instead of fresh installation, click on R-repair windows.
Allow the repairs to complete. You should be able to start and enjoy your PC from there on.
Oct 07, 2017 | ASUS Computers & Internet
How to open the dvd of sonic master X553m of asus
The sonic master technology is already built-in.
Run the Audiowizard to change the sound to use the technology.
Mar 04, 2015 | ASUS Computers & Internet
I cannot figure out how to open my dvd drive on my new asus laptop
What is the make and model of your laptop? Some new Asus laptops do not have CD/DVD drives - You need to use an external drive.
Jan 13, 2014 | ASUS Computers & Internet
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
I have upgraded my pc.The 2 CD-DVD RW dr ,do not play or record
I advice you to remove one driver and look whether the other is working. Check both the drives this way. Once you find them working, you can get back to your old system, that is, how it is now. This is not based on any logic, but it may work as your problem may be that your newly upgraded system got confused with the two drivers.
Apr 12, 2010 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Weird problem. CPU recognizes the sata, windows will not boot, recycles to start-up over and over. Tried with xp disc to repair, came back as "no hard drive listed. If I changer driver from master to slave...
It is possible that Bios/Cmos battery is not maintaining its charge. You might want to pull the cmos battery & check its voltage with a volt meter. It should retain 3volt DC. If it reads lower than 3v replace the battery. Once replaced you will need to reset all bios settings. If the battery checks out ok than continue.
The soulation to your problem lies within the Bios not your hard disk drive. Set the jumper you moved to slave back to master. Re-connect the SATA data & power connector to the motherboard. Boot up your PC & start pressing the Delete key on your keyboard every two seconds untill the Bios menu opends. (See page 2-14 section 2.3) in your manual.
You can not use your mouse while in the bios. Read page 2-12, section 2.2.1). This will explain how to move about while in the bios. Once the Bios opends you will be at the main menu. If your SATA drive is correctly connected you will see its model number listed there.
If you have two SATA drives connected you should see both. Take note of which is the master SATA1 drive. All SATA drives run as master drives. While in the Bios, SATA drives are shown from top to bottom. First /top drive will be the master drive. Next drive down is considered as slave.
Than open (OnChip SATA controller). Set this to [Native Mode] or to [SATA]. See page 2-16, section 2.3.5
Than open Boot. See page 2-30, section 2.6, Open Boot Device Priority section 2.6.1 Here is where you need to set the boot order.
(The boot order is not set correctly & this is why windows does not see your hard disk drive & showed the message "No hard drive listed").
If you have a floppy disk drive connected to the system set it as,
[1st Boot device]
Change 2nd Boot Device to [CD-ROM]
If you have two CD/DVD-ROM drives in your system make sure you set the Master CD/DVD-ROM here & not the slave CD/DVD-ROM drive.
3rd Boot Device should be the primary [SATA1 drive], connected to SATA1 port on the motherboard. See page 2-30 section 2.6.2
The drive with windows installed shoud be listed as 1st.
Save your changes & exit the bios. Your system will auto re-start.
If you had a working operating system on the drive it should load.
If you need the motherboard manual or drivers you can download them from Asus web site link below;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
Cheers!
If you are still having troubles, post your question here.
Mike
Sep 24, 2009 | ASUS P5S800-VM Motherboard
My CD will not open when I press (''open'')
Hi, Gary.
Give these a try:
In My Computer, right-click your CD's drive letter and select Eject.
Open a paper clip and insert in a tiny pinhole in the drive.
Hope one of these helps.
Sep 10, 2009 | ASUS DRW-1608P Dual Layer DVD±R/RW...
When two drives are connecting cd or dvd it detects only one.
If they are IDE drives, then you need to set the jumpers on the rear of the drives. You should set one to master and the other to slave.
Mar 24, 2009 | ASUS Computers & Internet
Aug 29, 2008 | Acer Aspire 3610 Notebook
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Acer (KV.16X04.007) DVD Drive Logo
1,195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
