Question about ViewSonic VA902 19" LCD Monitor
Monitor shivering hi, i have viewsonic monitor va902b, but it's not working anymore :( green led is blinking all the time- i can't switch monitor off or or... and sometimes when i manage to get monitor on, the picture is not clear, i can see that there are some shapes, but mainly there's is only stripes vibrating on screen. can anyone help, is it repairable, or should i consider this monitor to be waste?
    Sergeant:
    Champion:
  • 225 Answers
There's an internal electronic part/s of your monitor that is cold soldered or defective. I suggest to bring it to an authorized service center to properly diagnose & fix the problem. regards
Posted on May 25, 2009
VA902b monitor will flash on for half a second and then go black even though the light shows green. Didn't have any problems with the monitor until updates were automatically installed for windows....
The "sleep mode" is probably set too low.. or a "power saving" mode is set too cut off too quick..(sorry for the low information) .. I am at work on an Apple.. geeezzzz :(
Jun 06, 2017 | ViewSonic VA902B 19" LCD Monitor
VA902b Viewsonic monitor just went black this morning while working. Tried updating driver. Reboot. Does display during startup and goes black again. Monitor problem or hardware? I have 2 monitors.
The best thing to do to isolate the problem is to connect the problem monitor into a known working CPU. If the same problem occur, then the problem is the monitor. You may need to check if the power light (LED) is blinking or no light at all.
If there's no light, you may start replacing the power cable if the cable is detachable. But if it's built-in to the monitor, then send it to the authorized repair shop. They need to check if the panel is shot.
Thank you and good luck!
Nov 01, 2010 | ViewSonic VA902b 19" Monitor
Need Cable Connector for VA902b monitor
Any PC repair shop should have this standard VGA DB15HD cable. Or just go online, it is just VGA CABLE 15-PIN/3-ROW male to male.
Apr 05, 2010 | ViewSonic VA902b 19" Monitor
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other...
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Dec 09, 2009 | ViewSonic VA902b 19" Monitor
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
ViewSonic VA902 19" LCD Monitor Logo
214 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
