Question about Symbol LS2208 Handheld
Adc-01244 - won't hit enter after scanning barcode
Can't open attached file with my work computer. Is there anyway I can look at without downloading a reader for it?
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: Hand held scanner LS2208
At the Symbol web site they have some instuctions for programming a 'Tab' at each scan.
Follow this link....
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11124&sliceId=SAL_Public&dialogID=58352294&stateId=0%200%209199403
Posted on Jun 21, 2008
bluegreenash
  • 661 Answers
SOURCE: Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Posted on Jul 09, 2008
SOURCE: no data is transmitted
you need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
Posted on Jul 22, 2008
Why i cannot scan 1 digit number
Did you make the barcodes using Code 39 or 3 of 9? If so, the scanner defaults to reading between 2 and 55 character Code 39 barcodes. Go to the Motorola Solutions support portal and search for Article ADC-00404 portal motorolasolutions com. Print the article and scan the Code 39 Any Length barcode. Once this is done the scanner will read all Code 39 barcodes.
Aug 12, 2014 | Symbol LS 4278 Barcode Scanner
WHY MY LS4278 AFTER SCANNING IT IS AUTOMATICALLY NOT GOING TO THE NEXT LINE
The scanner needs to be programmed to hit the enter for you. Motorola Solutions article ADC-00316 has a link to the barcodes you need to scan: Scan Options, Data Suffix and Enter. This link should take you there: portal motorolasolutions com
Aug 11, 2014 | Symbol LS 4278 Barcode Scanner
How do i get my scanner to do "enter" without
Hello Severiano,
this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document. https://docs.symbol.com/attachments/ADC-01244.doc
Aug 02, 2011 | Symbol LS2208 Handheld
Add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
Jan 28, 2011 | Symbol LS1902T Handheld
I have a Symbol 1908T-1200 which works fine, but I need it to send a line return code after the data. How do I accomplish this.
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
Oct 11, 2010 | Symbol LS1908T Wired Handheld Barcode...
I would like to programm my barcode to push enter twich when i scan a product
Hallo Jason,
Oct 05, 2010 | Zebra Symbol LS 1203 Barcode Scanner
When using the scanner to scan books in a library setting I have to push the enter button on the keyboard after I scan the book. Is there a setting so you do not have to hit the enter button; it will just...
Hallo Jason,
Sep 15, 2010 | Symbol LS2208 Handheld
Computer is very slow and every time i open wepsite it get stack
turn on the computer and keep on pressing the F8 key> select safe mode> login to desktop> go to run and type "temp" (without quotes) then hit enter and delete all the files> go to run and type "%temp%" (without quotes) then hit enter and delete all the files> > go to run and type "msconfig" (without quotes) then hit enter then goto the startup tab and uncheck all the unnecessary items hit ok and do not restart the computer> go to run and type "inetcpl.cpl" (without quotes) then hit enter then goto the advanced tab and click on reset to reset the internet explorer.
Then restart the computer it should work fine now.
Sep 06, 2010 | Computers & Internet
Having to hit enter after scanning an item
You would need to setup those three scanners correctly, the solution is described on the manufacturers website, please see http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=ADC-01244&sliceId=SAL_Public&dialogID=189660762&stateId=1%200%20189654426
Jun 29, 2010 | Symbol LS 2208 Barcode Scanner
Scanner enters immediately upon every entry. I need to make multiple entries then enter all at once.
You can create a barcode in Code 39 that contains $M. Then scan the Enable Code 39 Full ASCII barcode from the Symbologies section of the LS4000 Series Product Reference Guide (Adobe page 93 of 182). If you are unable to create the barcode Knowledge Article ADC-00266 contains the $M barcode. You may run into problems with your application if it does not see a Control M as an Enter. If this is the case the article contains instructions for addressing this problem as well.
Jun 09, 2009 | Symbol LS 4000i Handheld
Symbol LS2208 Handheld Logo
55 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
