Question about Olympus FE-210 Digital Camera
Olympus FE-210 lens is stuck & gear studders 1/2 way out & stops.
Can view pictures but can not take any becuase the lens gets stuck once 1/2 or 2/3 of the way out.  It comes out to that point and then gears skip for a bit and it stops trying.  This happened on a trip to the beach so my gues is that sand or somthing is in the lens sides or somthing.
I can take the camera apart but getting the lens piece out became a matter of dismantleing the entire camera which I would prefer not to do.  I had the camer probably at least 1/2 way apart; bot rear and front casing off along with LCD display detached.  But the lens seemed to be barried under the "motherboard" of the camera and it seemed difficult to go farther with wires and such wrapping from the board to the camera base structure.
Josh
  • joshd00 May 18, 2009
    I'm not paying $50 to repair a $100 camera..  I'll just buy a new one and it will not be an olympus.
    Problem fixed...
    Also, it looks like the lens is coming out all the way then it makes some clicking noise, the LCD is black.  This seems to be a common Olympus FE-210 problem where the lens piece needs to be replaced.  Lens or shutter problem I guess.  Regardless, if that is the problem the only fix in my opinion is a new camera that will not do this.
    President:
  • 919 Answers
Http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $47.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 18, 2009
When I turn my FE-230 on it opens and closes the lens multiple times before it stops.Looking in the window the images are blured.I use the auto settings and take pictures of machines.The batteries are...
This is a well known problem with these lens. They have very small focus gears and they get stuck quite easily by sand and dust. The lens unit has to be taken apart and the gears should be cleaned under a microscope. I repair these every day. I would suggest you contact a local camera repair center and let them clean it.
Tom
Mar 03, 2010 | Olympus FE-230 Digital Camera
The lens opens and makes a ticking sound but light stay orange
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 15, 2009 | Olympus FE-210 Digital Camera
Memory card stopped the camera working
a 1 GB card is SMALL - and is likely very very slow in saving pictures. you may want to tryt to get a different, larger memory card
Mar 13, 2017 | Olympus FE-210 Digital Camera
Olympus FE 210, not turning on
clean the battery compartment and check the door for debris such as hair or sand
Nov 25, 2008 | Olympus FE-210 Digital Camera
Problem with fe-210
Lens gears are probably broken off, or other problem with lens. Will need to replace lens, or may possibly be repaired. I've repaired a few lenses with gears broken off, by replacing broken off posts with similar size plastic pieces(drilled holes and super glued in place, being very careful). Still working months after repaired. Olympus repair shops can replace anything needed, but at a HIGH price; sometimes cheaper to replace camera than to have them work on it.
Jun 08, 2008 | Olympus FE-210 Digital Camera
Need help wi Olympus FE-210 camera
The lens is stuck in the on postition. I don't know what happened but do you know what i can do to fix the problem? It's only a year old and is like brand new, I can't use it. Thanks
Jun 07, 2008 | Olympus FE-210 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
How do I get the date to show and print on the picture of a fe-210?
Do you have the manual? If so, the instructions on how to do that start on page 33.
If you don't have the manual, here it is:
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Jan 12, 2008 | Olympus FE-210 Digital Camera
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
Olympus FE-210 Digital Camera Logo
464 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
