Question about Dayton Split Condensing Unit Air Conditioner
I need the wiring diagram for an outdoor split system condensor unit mine caught on fire and i cant see the diagram on back of panel
  • 2 more comments
  • steve
    steve May 11, 2010
    What burned? What needs to be re-wied?
  • Dennis Boxerman May 11, 2010
    If you can get me model and serial numbers, I might be able to get the info you need.
  • Tyshizzle May 11, 2010
    Every unit is different. The make and model need to be identified in order to get a new wiring diagram.
  • kabir Jun 20, 2013
    i have need digram
    Guru:
  • 587 Answers
i need the wiring diagram for an outdoor split - image11.gif I've been trying to copy and paste a typical AC wiring diagram, but for some reason I am unable to thru this sight. Maybe if you post your email address I can email it to you.
Posted on May 20, 2009
  • john lavigne Sep 24, 2011
    Well everything was burned up i have heparts but nhoone has the manual for it Model# M-s30g-043k can u help me ?
Need a wiring diagram for split system heat pump model number ch5536vkc2
need more information to help you.
1) is it single or 3 phase?
2) what power does it have? (example 30000 btus )
3) is it for the indoor unit or for the outdoor unit,? or both?
4) does it has an electronic circuit board in the indoor unit?
5) do you need only the field wiring diagram from indoor to outdoor unit?
Post me back with some details and I may help you out
Best regards,
Silvio
Dec 08, 2014 | Heating & Cooling
Daikin split system air con dead
Split system Air conditioners are very often on two or more separate breakers, with a control voltage (24vac commonly) connecting their operation. the condensor unit and out-door fan generally on a 220 vc 'paired' breaker, possibly a quick disconnect near the unit with fuses inside, or an independant breaker pair, and the evaporator unit with INDOOR fan on a 110 or 220 vac breaker.
switch the fan to 'ON' at the thermostat... this is the midpoint of the system electrically. If the fan comes on check for voltage at the condensor unit. a check to see if the thermostat is the problem... remove the thermostat and connect the red, green and either the white or yellow wires (not both) if you chose white you should have heat...yellow AC...
most split system AC have a small buss fuse on the control circuit board of the indoor unit. looks like a glass tube with metal caps held by metal clips. In 40+ yrs experience I have found it is more likely one or both of the 30 amp buss fuses near the outdoor unit (replace both even if one is still ok) or a 30 amp breaker in the quick disconnect box.
In many systems the control voltage to the thermostat derives from a transformer in the outdoor unit... it could be as simple as a broken wire. Without a full diagnostic, a complete description of the unit ( AC or heat pump, etc) this is all speculation
Nov 19, 2013 | Heating & Cooling
The control board on my furnace is blinking 5 times. What does 5 blinks mean? Also what do 6 blinks mean?
What make/ model is your furnace? Do you have the wiring diagram to the unit? Usually on the inside of the heater panel on a split unit where the heater is in one location and the outside unit (condensor) is outdoors.
Aug 02, 2011 | Heating & Cooling
Dakin outdoor fan always running in my split system
This is a low voltage short in wiring. You will need to divide and conquer the low voltage wires until you find it. I could be a control board but most often it's the wiring.
Mar 31, 2009 | Heating & Cooling
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Ruud A/C condensor unit won't come on
It sounds to me that the wire going to y2 on the furnance coming from the thermostat was not wired back up this is the wire that supplies control voltage to the contactor on the condensing unit. I would call the installer who changed the furnace out back to remedy this problem.
Jun 01, 2008 | Heating & Cooling
Dayton Split Condensing Unit Air Conditioner Logo
531 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
