Following paper jam on usb connected printer, paper jam cleared, printer window message----still says paper jam. Printer reset to factory defaults and message cleared. Print rollers checked and cleaned, But paper will not feed automatically into print rollers although placed in tray properly, although prints each sheet individually when gently pushed down to edge of rollers
Comments:
May 18, 2009
- printer has had little use so rollers are not worn out, paper feed slot not blocked
Rollers could be worn out. Also could be a problem with the paper sensor. Not sure what type of sensor this printer uses. Some just use a pressure switch, others use a light sensor.
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
I just received this printer from my daughter and it has been setting for awhile and is dusty. How do you suggest I clean it so that the paper will feed through the way it should?
when i try hit scan it automatically says downloading application list and then can not retrieve...
(More)
when i try hit scan it automatically says downloading application list and then can not retrieve list I havent used the scanner part for a long time and I dont have the all in one center in my programs
