Question about True TD-50-18 Beverage Cooler
How do you remove the compressor fan on true bottle cooler
4 Suggested Answers
SOURCE: True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's overload or capacitor may be out.
Posted on Sep 13, 2008
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
  • 1252 Answers
SOURCE: my true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
Posted on Jun 29, 2010
I have a True tbb-2g that recently froze some beer in bottles and also a lot of moisture on bottles still in cooler that I have not enjoyed yet ! it is no froze up and compressor was replaced 3 years
Is the condenser clean and clear? Is the fan running? Sometimes when the fan fails the compressor runs and runs and runs. First thing you need to do is go to the supermarket and pick up a red stick thermometer and find out what kind of temperature you have. Try setting the temperature warmer. Is the coil iced up at one end? If it is there is a good chance the system has a leak and needs a look at from a tech with some tools. Hope this helps good luck.
Oct 21, 2014 | True TBB-2G Commercial Refrigerator
How do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
My true back bar cooler dosent cool it is not iceing over
Start there.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Cooler coil freezing up
Way too many thing's can cause such problem's. Most important with bottle coolers are clean condensor, good condensor ventilation, do not overstock and block evaporator circulation. Then you get to component failures, failed thermostat or improperly positioned sensing element, failed evaporator fan, icing of the evaporator section from fan or gas charge problems, contamination in gas curcuit causing cap tube blockage, compressor overheat shut downs from real or defective component issue's. Trouble-shooting is a plan for cause elimination, start with the simple end and move out from there?
Jun 29, 2009 | True TD-95-38-LT Beverage Cooler
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
May 03, 2009 | True Refrigerators
I have true refrigrator cooler. its not working. compressor is not running. so what m i do.
If the lights are on and fans are on its most likely the srarting compnents on the compressor. Remove from the side of compressor enough to shake if it sounds like a box of matches its fried,replace.
Mar 25, 2009 | Refrigerators
True TD-50-18 Beverage Cooler Logo
21 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
