Question about Garden
Stihl FS 110 brush cutter loop trimmer ''weed eater'' won't start. I've changed gas and spark plugs and it still won't start. Tool is 5 years old. Help! D.W. from NC
  • dacleggs May 22, 2009
    Thank you for your helpful advice. It was a carb problem.
    President:
  • 1,902 Answers
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
  • Jeremy Reddick
    Jeremy Reddick May 22, 2009
    You are welcome have a great day
Stihl fs 38 weed eater no spark
change the spark plug and test it again if no spark still it may be a broken wire or the coil has gone bad.
Jul 18, 2016 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Fs 85 loses power in the heat
Change all filters--and spark plug. Use a good cleaner in fresh fuel. dump the old first. use premium fuel--it has less ethanol in it
Jul 14, 2014 | Stihl FS 85 Weed Eater
My stihl weed eater fs85 hard to start when hot
Try loosening the gas cap to relieve any pressure, then tightening it back up. Usually you will just need to barely unscrew it and then screw it back even before you pull the rope.
Jul 13, 2014 | Stihl FS 85 Weed Eater
Stihl fs85 gives off white smoke while running
change to stihl ultra oil and make sure you ratios are correct. also replace spark plug and spark arrester.
Oct 07, 2012 | Stihl FS 85 Weed Eater
My Stihl FS 85 Weed Eater gets no fire to the spark plug
older models have a pick up and condenser for spark. newer models have pick up and ignition module. the pick up rust the condensers and modules go bad. first take apart to expose flywheel then ck for rust on flywheel at pick up if rusty clean set pick up clearance to that of a matchbook or ten thousands of a inch.if still no spark change condenser or module.
Jul 14, 2012 | Stihl FS 85 Weed Eater
Cutter runs for approx 10- 20 min and cut off and have to cool down before it starts again.
Hi, have you ever cleaned the unit out? If you have air pressure available, this is the easiest way to do it. Blow all the old dead grass, weeds ect out from the engine area of the Weed eater. If you don't have or have access to a compressor, take the unit to your local garage/service station and ask to use their air, or ask them to blow it out for you. This alone may cure the problem. However the proper mix is critical for proper performance also. If the mix is too lean the unit will over heat. Clean it out, and be sure of the mix ratio. You should be 'good to go'. Good Luck Vern
Jan 30, 2012 | Stihl FS 85 Weed Eater
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Garden Logo
1,438 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
