Question about Bunn U3 / SS 20500-0000 Coffee Maker
I PUT SWITCH ON FULL BREW AND IT STOPS WITHIN 30 SECONDS. WHEN I PUT IT ON HALF BREW IT DOESN'T STOP RUNNING
    President:
  • 1,618 Answers
It sounds to me like the Timer board is damaged, to test it set the small lock lever on the board to on (hopefully you have the electronic timer board in there) then select the cycle half or full then hold down the brew button until you hear 3 clicks then release. After about 1min or if using a measuring pitcher stop the brewer a 2ltrs, by turning the on/off switch off. Wait until flow stops then check water level and note. Turn brewer back on and press and release brew button and this time if it stops and gives you the same amount as you just got when programming then the timer is fine, just recalibrate it for full brew using the method above.
Posted on May 19, 2009
My keurig won't brew. It acts normal until it's time to actually brew the coffee. I can hear it start but then it stops.
Take out the k-Cup and put a big bowl under it.
Unplug it and wait 30 seconds - Plug it back in and make the largest coffee you can with NO K cup. Put a big cup under it to catch all the backed up water. Do this until it is running normal again then do it one more time (Run with no K-Cup in it)
Should fix the problem for a while.
Jul 29, 2014 | Coffee Makers & Espresso Machines
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
Nov 03, 2012 | kawasaki Krb750b Backpack Leaf Blower
My compressor blows the breaker after running about 30 seconds
Hi
By the breaker, I presume you mean the pressure switch that turns comp on/off between high and low minimum pressure.
There could be an internal problem within the electric motor that is only showing itself once the motor warms up.
If its possible disconnect the delivery tube from pump head or tank, and see how long the motor runs for.
If the motor doesn't stop then either the head valves have a problem or the pressure has a problem.
Hope this is of some help
John
Aug 02, 2011 | Air Tools & Compressors
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
Roper electric range non stop beeping!
I'm thinking a door switch problem and/or maybe an intermittent keypad connection. Failing that, the electronic control may have failed. We repair oven controls at www.fixyourboard.com.
Sep 30, 2009 | Roper FEP320 Electric Kitchen Range
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
248 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
