Question about Samsung 4 Series 4.2 cu ft Top-Load Washer White ENERGY STAR WA422PR
Nd error code on samsung wa422
Will not drain
    New Friend:
Never buy a Samsung anything.....
Posted on Mar 18, 2014
2 Suggested Answers
  • 6277 Answers
SOURCE: nd error code (not draining)
ABSOLUTELY!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 20, 2011
What does error code nd mean?
Hello, Vicky -
Is your washing machine a Samsung? If so, "ND" means "No Drain."
Read the information here:
https://removeandreplace.com/2016/03/22/samsung-washing-machine-error-code-nd-what-to-check-how-to-fix/
If I am incorrect in thinking your washing machine is a Samsung, you can Edit your question and add the make and model of your machine, so I or someone else can find an owner's manual for you and check the error codes for your particular machine.
Dec 24, 2017 | Washing Machines
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung washer had ND code, checked for clogs, could not find a filter on my machine, drain pump is in back inside panel, I removed hoses and found nothing, now machine will not start a cycle or drain, no...
to start with for your first problem "NF"if u Insert the drain hose too far into the drain it may cause a syphon effect stopping any water from draining out of the washing machine. and that will cause an "Nd" error.and 6e9df0b6-14e5-4444-9dca-eea3526ce7ee.jpgmake sureto the make sure there is power to the washer and if there isn't there is a good possibility it is the
Bearing Seal and Bearings:
May 26, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Samsung washer not draining
Our Samsung nd error was draining issues. You can Google ur model error codes and it will tell you what it is and from there you can order the parts off line and fix it urself to save some money. Was told by samsung tech who has fixed them for over 35 yrs the new engineering sucks and its made to break. His words not ours but we believe him after having so many issues with ours.
Jan 19, 2014 | Samsung Washing Machines
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Samsung front load has a code ND. Need to know how to drain it Thank you Carlos
ND error in your washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Jun 28, 2011 | Washing Machines
I have a ND code on my samsung front load washer
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Apr 13, 2011 | Samsung WF328AA Front Load Washer
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
Samsung 4 Series 4.2 cu ft Top-Load Washer White ENERGY STAR WA422PR Logo
77 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
